#1 |
Junior Member
Drives: MK7 GTI Location: Las Vegas
AC line condensation/wet?
Took a 4 hour trip to california and noticed this line was wet. Anyone know if this is normal?
Notice along line with black nozzle |
#2 |
Senior Member
Drives: Das Auto Location: PA
It is normal, that is the low pressure line which gets very cold so condensation forms.
#3 |
Senior Member
Drives: 2017 MK7 SE Location: NoVA
Its also the reason you can see water dripping or puddles under a car in the summer after it has come to a stop
__________________
PW | 3M CS Tint | JB4 | Clutch Stop | Clutch Bleeder Mod | Clutch Spring Removed | Snow Grate Removed | OBDeleven | ST Rear Sway Bar | Modified stock intake grill with AFE Drop-In |
#4 |
Junior Member
#5 |
Senior Member
Drives: 2016 GTI Autobahn Location: SC
#6 |
Senior Member
Drives: 2017 GTI Sport DSG Location: SE MI
When I was a service advisor, I'd get at least one freaked-out customer calling me whenever it was hot out, panicked about some fluid they saw leaking from their car. Every. Single. Day.
__________________
2017 GTI Sport DSG - Tornado Red | Recovering Honda Owner | Professional Car Nerd |
#7 |
Senior Member
Drives: 2016 Golf R Location: Florida
Now it's because their low coolant or tire pressure warning comes on at the first cold snap.
__________________
(Mostly) Posted by Josh/AWE. Flapper valves are open at idle, close after 1100 RPM during part throttle. Full throttle 1st-4th gear the valves open until throttle let off. 4th gear, 1500 RPM to full throttle closed, closed until 3500 RPM, then open until lift off throttle. |
Thread Tools | |
Display Modes | |
