FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Marketplace > Vendors Classifieds > Engine and Exhaust
Reply
Thread Tools Display Modes
Old 09-05-2017, 05:21 AM   #477
nate704
Senior Member
Drives: 2017 R
I'm glad that I got an AWE catted & resonated DP and don't have to worry about the CEL.
nate704 is offline   Reply With Quote
Old 09-06-2017, 11:43 PM   #478
BananaSlug
Senior Member
BananaSlug's Avatar
Drives: 2016 VW GTI SE DSG
Quote:
Originally Posted by Ian@MAPerformance View Post
Keep me posted on what you find sir...
The clamp between the midpipe and catback got loose due to the midpipe being slightly smaller than the catback.
__________________
2016 CSG VW GTI SE DSG | LP | Johnson Ceramic Tint | Cobb Stage 2 by MAP | 034 Dogbone Insert | IE IC | MAP Downpipe /w GESI cat | aFe Air Filter | CTS TIP | Eibach Pro-Kit Springs | Bilstein B8
BananaSlug is offline   Reply With Quote
Old 09-06-2017, 11:44 PM   #479
aprofoundhatredofjustin
Member
Drives: 2017 GTI
Quote:
Bout 2 weeks in with a gesi cat and no CEL
__________________
2017 GTI S - Integrated Enginnering Intercooler - Black Forest Industries Stage 2 Dogbone Insert - Burger Motorsports JB4 - Michelin Pilot Super Sports - MAPerformance Catted & Resonanted Downpipe
aprofoundhatredofjustin is offline   Reply With Quote
Old 09-07-2017, 06:40 PM   #480
Joel
Senior Member
Joel's Avatar
Drives: 2017 GTI 6MT
Pulled my vibrant spacer off and pulled the medium insert out and put the larger one in.
Still pulled a 49f3...
Going to try no spacer next... Probably should have started there.
If that doesn't do it I may try the 42DD spacer.
Knew I should have got the GESI...
__________________
JB4, MAP catted downpipe, IE Intercooler, Brisk Silvers, HPA dogbone, 034 motor/trans mount. Not installed yet Sachs SRE, iAbed rear main seal.
Joel is offline   Reply With Quote
Old 09-09-2017, 06:13 PM   #481
Joel
Senior Member
Joel's Avatar
Pulled the spacer out this morning.
So far so good.
__________________
Old 09-12-2017, 03:24 AM   #482
Amko
Junior Member
Drives: 2017 VW GTI S DSG, CSG
I am happy with the downpipe except for the fact that I can not get rid of the CEL. I have the L-shaped spacer from Amazon and I tried a couple different configurations and still get the CEL.
I was getting downpipe rattle on cold starts and between 1-1.5k rmp as well similar to a couple people on here. Sent a video to Ian but never got a reply. It ended up being the midpipe and the clamp not tightening down on it. Inserted metalic shield between the midpipe and clamp to help with the void space. Rattle went away instantly.
Now the only issue is CEL
Amko is offline   Reply With Quote
Old 09-12-2017, 03:27 AM   #483
BananaSlug
Senior Member
BananaSlug's Avatar
Should've gone for the GESI cat.
__________________
Old 09-12-2017, 03:32 AM   #484
Diggs24
Senior Member
Diggs24's Avatar
Drives: 2015 GTI; 2003 Saab 9-3 SS
Quote:
So far so good.
Tried it. Didn't work.
__________________
JB4 / IE Intercooler / MAP cat+res Downpipe
Diggs24 is offline   Reply With Quote
Old 09-12-2017, 11:33 PM   #485
Joel
Senior Member
Joel's Avatar
Quote:
I have had the CEL pop on twice now since removing the spacer.
However I am getting a different code now.
P042000.
Hoping there is a balance point between the two codes, lol.
Not sure what I am going to try next... anyone want to buy a slightly use vibrant spacer, lol...
Edit: bought a 42DD spacer... will report back after it gets here.
__________________
Old 09-27-2017, 07:58 PM   #486
HicBuda
Member
HicBuda's Avatar
Drives: 2016 GTI SE DSG LP DAP
[QUOTE=Amko;505106]
...I was getting downpipe rattle on cold starts and between 1-1.5k rmp as well similar to a couple people on here. Sent a video to Ian but never got a reply. It ended up being the midpipe and the clamp not tightening down on it. Inserted metalic shield between the midpipe and clamp to help with the void space. Rattle went away instantly.
What kind of metallic shield did you use? I have used heat wrap a couple of times and they work they're way out. Clamp can't definitely can't get any tighter. Always push exhaust forward when tightening as well.
EDIT: I screwed up the quote box
__________________
MAPerformance DP and stage 2 tune (Cobb)-Unitronic IC - CTS Turbo inlet pipe - aFe drop in+snow guard delete - RSE10 18 DSW 06
HicBuda is offline   Reply With Quote
Old 09-27-2017, 08:15 PM   #487
Diggs24
Senior Member
Diggs24's Avatar
I pushed exhaust forward and used muffler sealant in the joint. No rattles.
__________________
Old 10-25-2017, 04:21 PM   #488
HicBuda
Member
HicBuda's Avatar
I may just get exhaust tips to complete my exhaust setup. The Map DP/stock CB combo has gotten even better sounding and I heard my wife taking off in it yesterday and thought shit that sounds good. Folks at the auto cross last month also complimented on the sound as well. Afraid any catback will change that balance.
__________________
Old 10-25-2017, 04:50 PM   #489
Ian@MAPerformance
Senior Member
Drives: 2016 Golf 1.8T
Surprisingly, I kind of agree. Really like the sound of the DP with stock exhaust. Loud enough, and still gets some DSG farts
Quote:
Ian@MAPerformance is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
