FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Technical Topics > Exterior / Interior Care (washing, detailing, exterior repairs)
Reply
Thread Tools Display Modes
Old 09-02-2016, 07:54 PM   #18
The Fed
Senior Member
The Fed's Avatar
Drives: 2016 Golf R
Keep in mind that OEM glass has the VW logo on it. If you trade the car in the appraiser will note this and offer you less.
__________________
(Mostly) Posted by Josh/AWE. Flapper valves are open at idle, close after 1100 RPM during part throttle. Full throttle 1st-4th gear the valves open until throttle let off. 4th gear, 1500 RPM to full throttle closed, closed until 3500 RPM, then open until lift off throttle.
The Fed is offline   Reply With Quote
Old 09-06-2016, 02:51 AM   #19
wordsthatiwrote
Senior Member
wordsthatiwrote's Avatar
Drives: 2016 VW Golf GTI SE
Quote:
Noted. Thx.
__________________
AEM Intake | Forge BOV | Cobb Access Port w/ MA Performance 93 Octane Stage 1 | NGK Iridium BKR7EIX Spark Plugs gapped to .025
Future: Turbo inlet pipe + Intercooler
wordsthatiwrote is offline   Reply With Quote
Old 01-05-2017, 03:18 AM   #20
picollo
Member
Drives: mk7 tsi
Quote:
Originally Posted by sprinks View Post
What?! Safelite did mine for under 400. There's definitely non-oem glass now. Had mine replaced in march-ish with the Fuyao glass.
Were you pleased with them? I have got to change mine this month to pass the state inspection. Thank you in advance for your response.
picollo is offline   Reply With Quote
Old 01-05-2017, 08:50 PM   #21
sprinks
Senior Member
Drives: GTI Mk7
It's worked fine for me. No leaks, ~1.5 hours in the shop and a guarantee if a problem arose. I'm approaching a year later with no issues thus far. If i get another crack in it in a few years i'll replace it with safelite once again.
__________________
wheelwell & GTI mk7 journal
sprinks is online now   Reply With Quote
Old 01-07-2017, 03:17 AM   #22
picollo
Member
Drives: mk7 tsi
Thanks. I am getting quotes now...I may just have it done by them.
Old 01-09-2017, 01:33 AM   #23
2slowvw
Moderator
2slowvw's Avatar
Drives: 2016 GTI S
Got mine installed with aftermarket glass about 8 months ago for less than 300, no issues so far.
__________________
Cheap, fast, or reliable. Pick two.
2slowvw is offline   Reply With Quote
Old 01-09-2017, 01:57 AM   #24
picollo
Member
Drives: mk7 tsi
Quote:
I've got a couple of quotes, including Safelite...they're all above $350. This is in Charlottsville area. The original quote I got from Safelite was over $400...They lowered it to $365...I will try to get them to lower it some more...We shall see.
Old 01-16-2017, 01:51 AM   #25
picollo
Member
Drives: mk7 tsi
I ended up getting it changed by Glas Doctor in Charlottsville. Total came out to $304.
They were very easy to work with, very responsive and upfront about alll the fees, etc., unlike Safelite. Total out of pocket with Safelite, after discount, would've been almost $450. Thanks all.
Old 01-20-2017, 06:41 PM   #26
LeoA86
Senior Member
Drives: 2016 GOLF R W DCC
Just got mine replaced yesterday, install came out good, but my lane assists is not working properly. Sucks, but oh well, I guess I have to go to the dealer know to get that recalibrated.
LeoA86 is online now   Reply With Quote
Old 02-21-2017, 05:48 PM   #27
Skwangtang
Senior Member
Drives: 2015 MK7 GTI CSG Autobahn
I am almost positive Safelite removed the original rubber trim piece here...is this going to be a problem? I asked the tech about it and he said the windshield he installed had a rubber guard on it
Sent from my SAMSUNG-SM-G891A using Tapatalk
Skwangtang is offline   Reply With Quote
Old 02-23-2017, 07:05 PM   #28
gamille
Member
Drives: Boxster Spyder, '17 GTI
I had a similar thing happen when I had my parents' Santa Fe windshield replaced. It looked a little off, and when I inspected up close, the rubber trim at the top had been folded behind the glass, vice hugging it like it should have.
However, ours doesn't have a rubber trim piece, at least on top, outside of the windshield:
They may have just installed the windshield a bit lower than the original, making it more noticeable.
gamille is offline   Reply With Quote
Old 02-25-2017, 02:06 AM   #29
picollo
Member
Drives: mk7 tsi
I had mine replaced about a month and a half ago; watched the guy doing it...there was no trim at the top of windshield. To be honest, I've never noticed the gap before my windshield got cracked. Since I got it replaced, it's a different story however...that's the first thing I see when I approach my car from the front
No leaks so far...
Old 06-08-2017, 04:55 PM   #30
stubes
Junior Member
Drives: 2015 GTI SE
Thought I'd share this. I recently needed to replace my windshield due to a very large crack. My insurance would not cover OEM glass since my car is more than 2 years old, so I went aftermarket. Safelite came and installed it but the glass didn't fit correctly. The gap up top was pretty big and the rain sensor/rear view mirror piece wouldn't attach correctly. They came back with another windshield a few days later and had the same problem. They eventually gave up and installed the OEM glass for no additional charge. That glass, of course, fit perfectly.
I thought it was extremely bizarre that they couldn't get the proper size glass for a car model that is not rare at all.
stubes is offline   Reply With Quote
Old 06-08-2017, 06:36 PM   #31
BxGTI
Senior Member
BxGTI's Avatar
Drives: 2015 VW MK7 GTI, 2017 Audi A4 PP S Line2.0T
I had a MINI Cooper that had the windshield replaced with the OEM glass a few years back, the car was 9 years old at the time, my Insurance paid for it, I told them that I didn't want an aftermarket glass, they called me back with the approval.
__________________
2015 Tornado Red GTI MK7
BxGTI is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
