FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Technical Topics > Golf Engine / Drivetrain / Exhaust / Tunes
Reply
Thread Tools Display Modes
Old 02-13-2018, 02:59 PM   #1
Ironshade
Senior Member
Drives: 2015 GSW 1.8tsi 5MT APRis20+jb4. Powaaa
27.5psi taper 25psi redline
Is20
APR is20 93oct tune
JB4 stack
E30 fuel
Cts downpipe
Knn drop in filter
Forge BOV
APR turbo muffler
Nkg rs7 gapped .022
Southbend stg2 endurance wit 19lb lwfw (6lbs lighter then stock)
Log
https://drive.google.com/open?id=1E4...HK071xB8sFfcXT
(Video of log)
https://drive.google.com/open?id=19I...RtKwFp8Sjd4wdk
Old Race video on jb4 only (22-18psi) (LOG at end of video)
https://drive.google.com/open?id=1ZX...3SnlIIyno-CSI_
Car pulls great. Alot harder with stack
Same 99% perfectly flat road.
Previous best was 6-6.1 60-100mph on jb4 only (288whp 357wtq) 22-18psi 2’ better timing curve
Now i’m seeing 5.3-5.4 60-100mph. (Still have to get dyno)
Currently installing meth because IATs go up 40’ above ambiant in one pull. Should hopefully see good results! Maybe get me down to 5.1-5.2?
Ironshade is offline   Reply With Quote
Old 02-13-2018, 03:47 PM   #2
erichhart
Member
Drives: Golf Mk7 1.8t + Chevy S10 2000 4.3
Wow that is so nice!
Whats your 0-60 times for each?
erichhart is offline   Reply With Quote
Old 02-13-2018, 03:52 PM   #3
Ironshade
Senior Member
No clue. Traction sucks.. fwd is lame. But on a drag tire.. i’d guess somewhere in 4s
Old 02-13-2018, 09:11 PM   #4
MeltedSolid
Senior Member
MeltedSolid's Avatar
Drives: Mk7 Golf TSI Launch Edition
I have been considering doing the very thing you have. $300 for software actually designed for my turbo, and then the JB4 just for logging, ethanol, and maybe some methanol in the future. It seems you are getting very good results doing that very thing!
I'm curious what your 60-100 is with the JB4 in map 4 with 93. Is it slower or faster than when you were JB4 only with e30...
__________________
2015 TSI Launch Edition | Deep Black | 5-spd manual | APR Stage 1 + JB4 + IS20 swap | DIY Turbo Muffler Delete | 17" Enkei RPF1's | 034 dogbone insert V1 | BC Racing BR series Coilovers | ST 25mm rear sway bar | DIY HD Clutch Stop | NGK RS7 Spark Plugs | VWR Catted Downpipe
MeltedSolid is offline   Reply With Quote
Old 02-13-2018, 09:36 PM   #5
Ironshade
Senior Member
For me going from jb4 only it was well worth it, afrs where I want no more 51trims issues, speedlimiter, and tq limiter remove but biggest difference for me was the spool. Went from slightly lagged to instant.
93oct map 4 60-100 iíll have to test get back to you. Butt dyno it felt quicker then jb4 e30 tbh. My map is actually pretty agressive heres log from map4 93oct. Here is log to 6500rpm https://drive.google.com/open?id=1Hy...YCLiO4qv6Qledn
Old 02-15-2018, 11:04 PM   #6
Ton
Senior Member
Drives: Golf
You're right about the response Ironshade. I just got a tune after being different versions of JB for a couple years.
The tune makes the car noticeably more responsive all over. It takes away all the goopey response most VWs have.That feeling where you hit the gas and the car needs to think about it for three seconds is gone. There is still lag, there is still boost threshold, but it's all more linear.
Even at stock boost the car should run this way. Should come from the factory this way. Even the 1.4 Chevy Cruze turbo doesn't have that weird VW response.
Ton is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
