FORUM OPTIONS
Reply
Thread Tools Display Modes
Old 02-13-2018, 01:31 PM   #1
The Fed
Senior Member
The Fed's Avatar
Drives: 2016 Golf R
Many Piggyback Videos But None for the Zip Ties
Or none I've seen. I'm surveying under the hood for where to run piggyback wiring to make it aesthetically pleasing while avoiding the fans and serpentine belt. It seems by now someone must have discovered the "gold standard" for where run the cables and where to attach the zip ties, especially for the lower boost sensor. Are you that someone?
__________________
(Mostly) Posted by Josh/AWE. Flapper valves are open at idle, close after 1100 RPM during part throttle. Full throttle 1st-4th gear the valves open until throttle let off. 4th gear, 1500 RPM to full throttle closed, closed until 3500 RPM, then open until lift off throttle.
The Fed is offline   Reply With Quote
Old 02-13-2018, 06:10 PM   #2
nate704
Senior Member
Drives: 2017 R
yes, I am.
nate704 is online now   Reply With Quote
Old 02-13-2018, 06:17 PM   #3
Diggs24
Senior Member
Diggs24's Avatar
Drives: 2015 GTI; 2003 Saab 9-3 SS
__________________
JB4 / IE Intercooler / MAP cat+res Downpipe
Diggs24 is offline   Reply With Quote
Old 02-14-2018, 03:00 AM   #4
burtomr
Member
Drives: MK7 R
Quote:
Originally Posted by The Fed View Post
... It seems by now someone must have discovered the "gold standard" for where run the cables and where to attach the zip ties, especially for the lower boost sensor. Are you that someone?
Here ya go:
CABLES:
ZIP TIES:
burtomr is offline   Reply With Quote
Old 02-14-2018, 04:49 AM   #5
fastlax16
Senior Member
fastlax16's Avatar
Drives: 2016 Deep Black Golf R Manual
No zip ties, no issues in 2+ years.
fastlax16 is offline   Reply With Quote
Old 02-14-2018, 05:02 AM   #6
MeltedSolid
Senior Member
MeltedSolid's Avatar
Drives: Mk7 Golf TSI Launch Edition
https://www.google.com/search?biw=19....0.vf8ZVfHsQZQ
Ask a local enthusiastic PC builder or networking engineer.
__________________
2015 TSI Launch Edition | Deep Black | 5-spd manual | APR Stage 1 + JB4 + IS20 swap | DIY Turbo Muffler Delete | 17" Enkei RPF1's | 034 dogbone insert V1 | BC Racing BR series Coilovers | ST 25mm rear sway bar | DIY HD Clutch Stop | NGK RS7 Spark Plugs | VWR Catted Downpipe
MeltedSolid is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
