you could make low 400s or high high 300s whp on stock fueling, with fueling on 93 probably mid 450-470whp and thats pretty safe for stock engine
now with that info, i wouldn’t need the hpfp or the mpi right?
yeah, to make low 400-450 he could probably just get away with a lpfp pump, and a low E blend!Those are the fueling mods, so yes you would need some, or probably all, to achieve the 450ish HP level.
Wouldn’t the numbers vary a bit depending on if you’re referring to a GTI or R? Don’t the R’s have higher flowing injectors as opposed to the GTI?
Are these numbers (the 60-130) with or without MPI?
ok so for the ROW cars that already have mulitport injection, would any further mods to the fueling system be required considering it already has the side port injectors?
My limitation once the turbo gets shipped out, is 91oct, however i have the possibility of mixing it with C16 for track days. So would just like to get an idea as i already have the full bolt on package.
I pulled it out of thin air to be honest, it was simply to state if you are buying a GTI the VAST majority are modifying them. Even if its a simple drop in filter, or wheel spacers you have MODIFIED your car. I would dare to say 90% of GTI owners modify their cars to some extent, of course I have nothing to back that up, but you get what I mean. Some people will find anything to argue about I guess...
This isn't about arguing over nothing.
I know only a little about you and it comes from what you post on here. Seeing as how you are a vendor marketing a product for which there are performance claims I'm assessing how credible you are. It is helpful to me to know if you are prone to exaggerate.
