APR MQB Stage 3+ EFR7163 Now Available Worldwide
Arin@APR
GOLFMK7 Official Sponsor
Auburn, Al
B8 S4, MK7 GSW TDI
The APR MQB Stage 3+ EFR7163 Now Available Worldwide!
The APR EFR7163 Turbocharger System produces up to 536 HP and lays down 10-second quarter mile passes, all through a convenient and affordable, turn-key solution.
Read More: http://goapr.io/mqb3
A3SBQ
Norway
Nice ����
Obakong
CA
That kit is with fueling. Also does not need a built engine. His numbers are at the crank. I am running this same kit on a stock block.
I know an R owner that bent a rod on stock engine with this APR Stg3+ and had to rebuild the engine anyway. This was on 91oct file and gas in CA.
Take your chances.
MyGolfMk7
B5 S4, Mk7 GTI
Take your chances.
According to the APR chart on 91 the setup achieves 429 whp / 398 wtq. That doesn't seem like rod bending territory unless something went wrong, such as by pushing things on low quality gas.
