davidk1175
- Florida
Would be helpful to have the part numbers for the trim and lcd panel
Maybe I missed this...but are you able to change the mileage on the virtual cluster to match your existing mileage?
Might be something I'll be interested in once my drivetrain warranty is expired.
These days mileage is stored in the ECU not the cluster.
Now that we've got the FL tails retrofit figured out (minus some fault code ), what's the consensus with regards to the MK 7.5 digital cockpit?
I've read about about a shop in the UK that has performed several of these retrofits but I can't find any information about the retrofit as a DIY.
Anyone know of any part numbers or links with additional information? The cost of the pats and complexity of the installation/coding may make me pass up on this upgrade but I am still curious to know.
Should be possible with all modelsI have a 2017 Alltrack SE here in the US. Is the digital cockpit even possible with an Alltrack? Thanks!!
I have heard from some people that these clusters don't go dim enough at night. You might want to wait and sit in one at night before committing to an expensive retrofit.
So the new cluster automatically reads the correct mileage?
