Hi there,
I have a Golf MK7 TDI 2.0 and I've now purchased 2 sets of folding mirrors . I did the coding with OBD eleven where you go to Long Coding and you enable the 2 folding mirror options (Make one "Installed" and the second "Active).
The first set of mirrors I bought came with the blind spot assist option and there was nowhere for me to plug the separate cable as I don't have the all around sensors. I thought this was the issue so I bought a second pair of mirrors.
The second I believe are from a Golf R, and have only one cable as my standard ones. I plugged that in but again no luck, mirrors won't fold. Also the puddle lights won't work either.
When I go to Output Test on OBDeleven I can move the mirrors up/down/left/right so they seem to be working fine. But when I try to test the Fold In/Out option nothing happens.
Could it be that I need a new controller perhaps? I believe mine is the same as this one:
https://i.ebayimg.com/images/g/NzEAAOSwVKRaJ5-R/s-l1600.jpg
I also installed the Mirror and Door/Unlock controller on the door
https://i.ebayimg.com/images/g/BUMAAOSwLsBZT6Dp/s-l1600.jpg
Also to mention
In the Media display
Click "Car"
"Setup"
"Mirrors & Wipers", there is no option at all for Folding Mirrors.
Any help would be appreciated!
Dimi
Also to mention
Click "Car"
"Setup"
Dimi
