Checked mine after the car sat for 18-20 hours in the garage. It's about 60 degrees F at the moment. Read 12.28 volts according to my digital voltmeter. That means I lost 1/3 of a full charge from maybe a 30-degree drop in temperature and sitting? It read 12.54 the last time I checked. I did not have the alarm set either time. The battery is about 2 years old. I'll need to check it under the same conditions when it gets warmer again, perhaps I didn't wait as long the last time. Charged my jump box fully, just in case.
Of note is I checked the battery voltage with my VCDS using the engine module's advanced measuring vales, and the label, battery voltage. It read only 12.0 volts. My digital voltmeter is a decent autoranging Sperry that's supposed to self calibrate.
