AFS FAILURE JETTA GLI MK6 2013
fernando.alipaht
mexico
Hello friends, im gonna tell you in the best way i can what happened hoping to reach your polite help. Sorry about the english im from mexico, im not native.
My car is a jetta GLI 2013 MK6 2.0T
All began when some water went into my right headlamp, the ballast module got burned. So i had to buy another ballast module, i got this second hand ballast module, this is the picture:
I replaced the damaged part with the second hand part and all was OK, DRL, low and high beam lamps, quarters, all things works properly, but the AFS stops working. I made a log and it says the next:
Address 55: Xenon Range (J745) Labels: 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Revision: -------- Serial number: --------------
Coding: 081200010B000200
Shop #: WSC 00066 000 00000
ASAM Dataset: EV_HeadlRegulVWAFSPt 002016
ROD: EV_HeadlRegulVWAFSPt.rod
VCID: 377DCD578EB85FA6659-8062
Right_headlamp_power_output_stage:
Subsystem 1 - Part No SW: 4H0 941 329 HW: 4H0 941 329
Component: LeiMo rechts H02 0010
Coding: 860000
1 Fault Found:
5275953 - Power Output Module for Left Headlamp
C1081 31 [137] - No Signal
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 2
Reset counter: 232
Mileage: 77525 km
Date: 2048.14.28
Time: 18:40:03
I tried to make the headlught adjustment like the instructions below but its say error when i try it.
Software Part Numbers 5M0-907-357-E and above
Headlight Adjustment
[Select]
[55 - Xenon Range]
[Basic Settings - 04]
Select Basic headlamp setting from the drop-down menu.
[Go!] to activate the Basic Setting.
The meas. block field will show Running.
Adjust the headlights using their manual adjusting screws as referenced against a suitable aiming target.
[Stop] after any needed mechanical adjustments are completed.
Select Acknowledge basic setting
After the result of Finished Correctly appears click [Stop]
The adjustment should now be learned.
[Done, Go Back]
Don't forget to check/clear fault codes afterwards.
[Close Controller, Go Back - 06]
Does somebody knows what to do to fix it?
Thank you bros
dr_mat
Berkshire
Best bet is to try a vag com or obdeleven forum imho.
...if it creaks, it's probably made by VAG
