MAY 2016 mods 1/?
FULL LEFT/RIGHT SWITCHES AROUND GEAR BOX with HARNESS (420rmb)
BEFORE/AFTER:
I just put the switches on and didn't touched the wiring yet because I don't have lot of time for this mod (yet).
Here are the harnesses I received with my switches (next to old ones).
Basically, the new harnesses only have the new wires for the new buttons I added and they don't have the wires I have on my stock harnesses...
I'll have to take the new wires out of the new-harnesses and plug them in my old harnesses later to have functional new button.
Here are the Pins used on THESE harness:
LEFT(OLD): BLANK / Start&Stop / Blank (pin4 and 7 used)
LEFT(NEW): MODE / no wires / ESP (pin3, 6 and 10... how about the 9?)
RIGHT(OLD): BLANK / ParkAssit / ParkSensors (pin3,4,6 and 7 used)
RIGHT(NEW): TPMS / no wires / no wires (pin9 and 10 used)
So, as I said, I'll have to put the old+new harness in one later, to have full functional buttons. (+ VCDS that I'll see with my local APR shop)
For what I manage to understand from the packaging:
For
MODE, it's written to use pin3(YELLOW) wire to T73/pin34 (on ABS module, engine-bay) and pin6(BLACK/GREY) wire to T73/pin21 (on ABS module, engine-bay).
For
ESP, it's written to use pin10(BLACK/YELLOW
ish) wire to SC34 (which must be the Fuse34 used by Golfdave) but nothing about the pin9 which is confirmed by Golfdave and my voltmeter to be useful)
For TPMS, it's written to use pin9(Grey/Green) wire to T46/pin39 (don't know which module, and where, yet) and pin10(Black/Yellowish) wire to SC34 which should be the fuse34 also.
