Old 01-23-2018, 02:34 PM   #1
jcarl126
Drives: '17 GTI SE DSG
Custom DSG TCU Tune, Reflect Tuning
Hey guys,
Just wanted to share my thoughts on a recent TCU tune from Ian at Reflect Tuning...
Firstly, he's extremely knowledgeable and easy to work with. After figuring out the time zone change things, since hes normally EU (+6 hrs from my EST) we had a good rhythm of questions and responses going haha. I payed for the tune and a deposit on the tuning tool, i hooked up my laptop to the tool and my OBD port, turned my cell phone on hotspot mode and connected to the hotspot. One program was downloaded to allow control of my hardware, and we were in! I had him firm up the clutch pressure, increase shift speed, adjust the D and S shift points, set the Launch control at 3800 rpm and numerous other things. Drove it around for a day and noticed a slight trans slip in 4th really getting on it. Shot Ian an email back, asked to have launch control set to 3500rpm, MORE clutch pressure and up my Drive mode shift rpms by 200.
He took maybe 30 minutes to respond, said he had changed the file and he was available that night to update me! Hooked back up, 15 minutes later, I was packing everything up again. It was SO simple to do from home (i used my shop so i could hook the battery to a charger, just in case) or even on the road somewhere. Cant give him enough props and its was great to have him adjust minor tweaks i wanted - his communication, turn around AND pricing cannot be beaten.
Dont take this as an advertisement, i paid full price for everything. Just wanted DSG folks to know there are more options out there, especially for guys running Cobb APs where typical DSG tunes state "most likely only compatible with OUR ECU flashes" or so on.
JC
IS38, Custom IC, Stratified ECU/APR TCU, CTS Catted DP, MagnaFlow CB
RS7 Plugs, CTS TIP/Turbo Blankey/TMD, AFe DryFlow, ECS Turbo Inlet Tube
Revo Dogbone Insert, Seat Swap
jcarl126 is offline   Reply With Quote
Old 01-23-2018, 02:41 PM   #2
DZZLPWR
Nice
DZZLPWR is offline   Reply With Quote
Old 01-23-2018, 04:51 PM   #3
GTI_Joe
Drives: 2017 VW GTI SE DSG
Thanks for the info on this! So did your slight clutch slip go away? Were you able to specify minimum upshift points as well as min rpm downshift points when on decel? How's the smoothness of shifting around town (especially slow speed 1st and 2nd gear stuff)?
GTI_Joe is offline   Reply With Quote
Old 01-23-2018, 06:27 PM   #4
jcarl126
Slip is gone, holding power seems to be great!! Yes, the bump in shift rpm was exactly how i wanted it. Shifting is VERY quick and it snaps into gear, which is precisely how i like it. Minimal lag from a stop till engagement. He can adjust pretty much whatever youd like, from my understanding. give him a shout at Ian@reflecttuning.com - very nice dude. Tomorrow will be a dry day, ill give it a 3th to 4th full throttle try out and report back, but so far - excellent!
JC
Old 01-31-2018, 10:36 AM   #5
k0mpresd
Drives: audi q3
thank you for the kind words.
k0mpresd is offline   Reply With Quote
Old 01-31-2018, 01:37 PM   #6
jcarl126
Thank you for the continued help!
Seems my Ecu flash hadnít been requesting the right DSG torque values, allowing for a slow clamp from 3rd to 4th. New ECU flash was loaded and logged last night, sending the logs in today to both tuners to make sure that was the absolute issue. Also have a local shop hooking up vcds and doing s log, as well as checking Dsg fill
JC
