Old 12-28-2017, 03:59 AM   #52
railroader
railroader's Avatar
Drives: 2016 GTI Autobahn DP,Water/meth,turbo inlet pipe
Originally Posted by Gti jake View Post
There's a guy in this thread who did exactly that. DKM was a great improvement as expected!
EDIT: NVM, it was BFI stage 3
I placed the order for mine tonight! It's estimated ship date is the 10th which is pretty far out, so hopefully it'll come sooner
Either way I can wait!
Your gonna love it. Mine is getting much much better. I'm at 260 of the 700 break in miles. Bench bleed that slave assembly before you put the tranny back in to make sure there are no leaks lol.
Sent from my XT1254 using Tapatalk
2016 GTI Autobahn 6mt
IS38, Ceramic Coated and DEI wrapped APR DP catless, turbo inlet pipe, BMS water/meth, I.E. Intercooler,DKM Twin DIsk clutch, JB4, airbox mod with afe drop in, cts silicone intake hose, spulen short shift f/b s/s, 034 solid bushing set, Spulen charge pipe
1971 Chevy Nova rust bucket project
railroader is offline   Reply With Quote
Old 12-28-2017, 04:01 AM   #53
railroader
railroader's Avatar
Originally Posted by ATR View Post
I'm very curious to hear if anyone has gotten a chance to test the DKM and South Bend Stage 3 clutches back to back. I'm specifically wondering how they compare to one another as far as peddle effort goes?
I would bet money the dkm peddle feels much better than the SB just because of the twin. It takes less force to produce more bite because of the greater surface area with the twin disc/pp
Old 12-28-2017, 04:46 AM   #54
Yes! lol I'll definitely be doing that
Just the $500-900 savings alone makes it feel better than SBC, not to mention the more Oem feel and better performance
Old 12-29-2017, 12:07 AM   #55
steddy2112
steddy2112's Avatar
Drives: GTI SE, GTI Autobahn
Mine is shipping the 9th ^__^
steddy2112 is offline   Reply With Quote
Old 12-29-2017, 05:44 PM   #56
MiamiBourne
MiamiBourne's Avatar
Drives: 2016 Oryx White Pearl Golf R (Base/6spd)
I just ordered mine from Urotuning...no I have to find someone to install it!
Instagram: @miamibournes_golfr
My Build
MiamiBourne is offline   Reply With Quote
Old 12-29-2017, 05:50 PM   #57
railroader
railroader's Avatar
Do it yourself, it's not a hard job if you have basic knowledge and tools
Old 12-29-2017, 08:56 PM   #58
ATR
Drives: Pure White 2017 GTI Sport 6mt
A quality torque wrench is also a MUST for this type of work.
ATR is offline   Reply With Quote
Old 12-29-2017, 09:05 PM   #59
MiamiBourne
I've thought about it and I've done everything else on my R with the spring install being the most extensive work. I rent a garage though and it's a ways from my apartment. I think if I owned a home with a garage it would be a different story.
Maybe I'll revisit those Youtube video installs again...
My Build
Old 12-30-2017, 03:24 PM   #60
railroader
railroader's Avatar
Do you by chance know the size, length and pitch if the hardware? I'm guessing M6 or M8 but it would be nice to grab some ahead of time
The length of the pp bolts we're 3/4 or about 19mm
Old 12-30-2017, 04:30 PM   #61
Thanks man I'll see what I can find
Old 12-30-2017, 05:41 PM   #62
railroader
railroader's Avatar
I got mine at Fastenal
Old 12-30-2017, 07:58 PM   #63
railroader
railroader's Avatar
I would recommend buying an oem tb and using that. My TB is making noise so I'm going to have to pull my tranny again. The quality of the oem does look much better than the one that comes with the kit
Old 12-30-2017, 08:08 PM   #64
Blueballs
Drives: 2017 GTI S 6spd manual, Eurodyne Stage 2
How long would you say it took you to install the DKM clutch? Iím on the fence as if I want to do it myself. My concern is if the install went south, that it would take time to get it right. I work a lot, and donít always have time on my hands, but considering trying it because shops want to charge me $650+ for the install, up here in UT. I do have a garage, but I donít have a lift, or a transmission jack. I just have the tools needed to remove/install, and jack stands. Is it worth tackling it myself to save $$ for a shop to do it?
Blueballs is offline   Reply With Quote
Old 12-30-2017, 08:11 PM   #65
Blueballs
I believe it's m5x1.0 but I'll double check later when I get home
Did you ever find the exact specs for these bolts, so that I could also buy some stronger ones to install when I get this clutch?
Old 12-30-2017, 08:22 PM   #66
railroader
railroader's Avatar
If your capable of doing it yourself then I say do it. It's not hard. No I can have the transmission out in 1 1/2 hours or less, putting it back in was a little more difficult cause my tranny jack is garbage and don't work well for transaxle. The most tedious part is tightening the pp down cause the are 27 bolts and have to go star/criss cross pattern to tighten and only tight each one 1 turn at a time then once it's all seated take each bolt out one at a time and put loctite on and torque to 10ft lbs. I have to pull mine out again to change the TB/slave assembly again.
Old 12-30-2017, 08:23 PM   #67
railroader
railroader's Avatar
I will double check when I get home on the thread but I'm almost positive that's it and they are 3/4in long or about 19mm
Old 12-30-2017, 08:28 PM   #68
Blueballs
That joint where the clip is where it leaks from. It is very flimsy. They are sending me everything minus flywheel and it will be here tomorrow. I'm going to put it all together and see if the current clutch works ok. I sure no fluid got on the discs to contaminate them so I will have an extra set of discs and a pressure plate.
Would the OEM throw out bearing work with this DKM Stage 3 clutch? Just wondering if I should buy the OEM TOB and use that instead of the one DKM provides, just so I donít get this problem during the install.
dkm twin disk, stage 3
