Old 09-05-2017, 05:22 PM   #409
nype
nype's Avatar
Drives: 2016 GTI Performance - DSG - Carbon Grey w/Leather
Originally Posted by Jedimk7 View Post
Ah sorry didn't see you were from Sweden, a lot of people leave XDS alone, just turn starting vibration off
Sent via Pide Piper compression app
I'd try starting vibration first. Then maybe XDS. I left XDS alone.
At least try one at a time. Not both at once.
nype is offline   Reply With Quote
Old 09-05-2017, 06:59 PM   #410
wide
wide's Avatar
Drives: Golf GTI PP Facelift Mk7.5
Thanks will try tomorrow!
My Youtube Channel ** GTI MK7.5 Performance Pack ** Subscribe for some trackday videos to come
https://www.youtube.com/channel/UCOQ...9L-iuT91cKxsjA
wide is offline   Reply With Quote
Old 09-14-2017, 06:46 AM   #411
mk7gti2.0
Drives: 2016 VW Golf R
It's not the torque limiter that your deactivating, it's the adaptation right above it that says starting vibration reduction. Should pop up with a drop down menu and give you a choice between maximum strong normal and deactivated.
mk7gti2.0 is offline   Reply With Quote
Old 09-14-2017, 10:09 AM   #412
wide
wide's Avatar
Jesus. How did i missunderstand this..
Now i have deactivated the starting vibration instead!.
Thanks mate!
Old 09-14-2017, 05:45 PM   #413
nype
nype's Avatar
Now i have deactivated the starting vibration instead!. Works fine!
Thanks mate!
Have you noticed a difference?
Old 09-14-2017, 08:07 PM   #414
wide
wide's Avatar
Yes but it didnīt feel any good to the drivetrain..
I made a movie with the different on my car, maybe the Conti 6 is to sticky..
https://youtu.be/jL_7Gtu2Gyc
Old 09-14-2017, 08:19 PM   #415
nype
nype's Avatar
Well ya. With stock tires, suspension etc this will give more wheel hop if you just floor it from a stop. You can control things with the throttle, of course.
The benefit of this change is that torque is not cut in the first 2 gears. You have more control.
Old 09-14-2017, 09:08 PM   #416
wide
wide's Avatar
Ok, i understand....
But thought it was really hard control the wheel hop. Maybe i have to class again..
Old 09-14-2017, 09:15 PM   #417
Jofa73
Drives: Gti clubsport
Buy insert for the dogbone mount to lessen the wheel hop.
Jofa73 is offline   Reply With Quote
Old 09-22-2017, 06:08 AM   #418
949
Drives: mqb
audi s3 2015.
i was able to do a deactivate.
so to feel it working, i have to floor it from a dead stop right?
949 is offline   Reply With Quote
Old 09-22-2017, 02:00 PM   #419
Oldschoolmk7
Drives: Mk7 GTI
Originally Posted by iNeedMorePSI View Post
Pull green 40amp ABS fuse in the engine bay fuse box. The only way I can turn it off on my early 2015.
Sent from my SM-G935F using Tapatalk
Thank you for that! .
Holy crap, full power in 2nd finally. I'd rather spin than bog anyday.
Old 01-15-2018, 05:34 AM   #420
VoVegas
Drives: MK7 GTi
Short story, do this mod! It really helps and truly truly deactivates that damn pesky traction control for good! 1st and 2nd feel even more awake and responsive under throttle. The word responsive doesnt really capture what I mean, but its close lol...Maybe it just has more feel i suppose. I don't feel the computer getting in the way AT ALL.
Bye bye nannies. bye bye.
Also, for what its worth...
Using obdeleven I turned traction control off, then made sure it was off when I went back into the control module>brakes>adaptations>start vibration-deactivated (this was previously on "strong" from the factory or something) AND torque limiter off/deactivated (this feature was already off when I got to the screen btw)
2017 S non-peepee, 6MT, ECU is tuned via cobb accessport. Thanks for all the info and anyone else posting should go back to page 1 cause everything youll wanna know is already here (pp, non-pp, dsg, tuned untuned, VCDS obdeleven, and if this will work)
VoVegas is offline   Reply With Quote
Old 01-15-2018, 06:01 AM   #421
adam1991
Drives: GTI Mk7
I see so much overuse of the word "nannies". In most if not all cases, they're driving the car way better than you possibly ever could.
Whenever I see someone use "nannies," I think that person insists that his skills are superior to the technology. I also think that person is wrong and is in denial.
Old 01-15-2018, 07:00 AM   #422
nype
nype's Avatar
What if someone thinks that highly skilled means spinning the front tires at will?
Old 01-15-2018, 01:47 PM   #423
Worldpacgti
Worldpacgti's Avatar
Drives: Mk7 gti
In a straight line, those nannies absolutely take the performance out of the car. They are not there to maximize performance, they are there to keep the car on the straight and narrow.
Eurodyne IS38, 3" catless DP, Unitronic intercooler, Autotech intake, CTS turbo inlet pipe, CTS turbo outlet pipe, CTS TMD, CTS dogbone insert, H&R sport springs, Eurodyne TCU tune, CTS Turbo BOV, CTS throttle pipe, ECS turbo blanket, CTS engine and Transmission mounts
Worldpacgti is offline   Reply With Quote
Old 01-22-2018, 07:47 PM   #424
Count
Drives: Mk7 r
Just fyi..i did all the changes on my mk7r...it did break loose easier however after 100klm per hr traction controls comes back on??
Weird thing to happen but I actually like having it on at those speeds lol
Count is offline   Reply With Quote
Old 01-22-2018, 08:01 PM   #425
drrck
Drives: 2015 GTI PP/SE/LP
Yes VW would prefer you not wrap your car around a tree
ED Stg 2 Adjustable / ED DSG Tune / HPA Core Interlock / I.E. Intercooler / Ferodo DS2500 Pads / Stoptech Slotted Rotors / 034 Intake
drrck is offline   Reply With Quote
