FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Technical Topics > GTI Engine / Drivetrain / Exhaust / Tunes
Reply
Thread Tools Display Modes
Old 01-17-2018, 12:08 AM   #137
afman916
Senior Member
Drives: 2016 GTI SE Pure White
Quote:
Originally Posted by jcarl126 View Post
I just commissioned having one of these built, but decided to go through with it outside of ebay. Gared, the builder, might be a member lurking around on here - but all USA hand made, i figured what the heck, give it a shot! like the stealth look anyway. Gared has been very responsive so far and is an AVID VW guy
https://www.ebay.com/itm/VW-MK7-GTI-...53.m1438.l2649
Care to share any specs man? Interested to compare this against the eBay intercooler that's the topic of this thread. Looked at his listing but don't think I saw any specs (may have overlooked them though).
afman916 is offline   Reply With Quote
Old 01-17-2018, 03:05 AM   #138
AtlantaDad
Senior Member
Drives: Night Blue 2016 GTI Autobahn DSG PP LP
Seems decent, and I'd probably trust it more than one of the cheap knock-offs. But at $600 shipped, I'd rather just wait for a deal on the IE.
__________________
2016 GTI NB PP LP | Cobb AP w/ MAPerformance Stage 2 | MAPerformance Catted/Resonated DP | APR TIP | AFE drop-in w/ snow guard delete | 034 Dogbone INSERT | (coming soon) IE IC
Thou shalt read this first: http://www.golfmk7.com/forums/showthread.php?t=18297
AtlantaDad is online now   Reply With Quote
Old 01-18-2018, 01:56 PM   #139
ErBall
Junior Member
Drives: A3 MQB
Is that a tube and fin design? If so, itll cool fine but youre gonna be seeing some pretty hefty pressure drop across the core.
ErBall is offline   Reply With Quote
Old 01-21-2018, 05:07 AM   #140
George Ab
Senior Member
Drives: GTI MK7, BMW E90
Received the other day and finished install. Overall I was quite impressed with build quality of the cast end pieces, welds of cooler and machining of interface pieces. Currently pricing is $279 on Aliexpress, I purchased for $253 with hoses and clamps (originally $215, but seller contacted me and requested an additional $38 as they incorrectly priced shipping). I did have to break out a file to knock down a weld for sufficient clearance for the radiator to lock into. As previously noted the end pieces that hold the clip to lock the assemblies into frame needed to be hit with file to get the clips on. I needed to go to the hardware store to get some 4mm and 5mm screws and washers to hold down the A/C cooler. The OE cooler has plastic clips holding.
George Ab is offline   Reply With Quote
Old 01-21-2018, 03:04 PM   #141
Oldschoolmk7
Senior Member
Drives: Mk7 GTI
Thanks George for taking the plunge. Yeah, it is a really nice IC for the $. Enjoy!
__________________
2016 GTI S two door
Bone mutha phuckin stock...
Oldschoolmk7 is online now   Reply With Quote
Old 01-21-2018, 03:17 PM   #142
Lord_Flexington
Senior Member
Lord_Flexington's Avatar
Drives: '15 GTI LP PP|'01 CBR 929
Quote:
Can you post the examples of those screws and washers?
Sent from my SM-N950U using Tapatalk
__________________
2015 GTI S PP//JB1//DP//INJEN CAI//GFB DV+//VMRV705//VWR SPRINGS//PZERO ROSSO//SPULEN SS//RACESENG//OBD11//Deep Pearl Gang//BIG WANG GANG
P1 GTI TCR-->http://www.golfmk7.com/forums/showthread.php?t=25994
Lord_Flexington is offline   Reply With Quote
Old 01-21-2018, 10:23 PM   #143
George Ab
Senior Member
Quote:
Below are the OE fittings for the A/C cooler. The end piece casting has a slot and 5mm for lower and 4mm for upper to hold A/C cooler. Below is my hillbilly engineering. I could of done better, but Home Depot was about to close and I wanted to finish that evening, so go ahead and laugh at my hillbilly engineering, but it is functionally sound.
Old 01-21-2018, 10:37 PM   #144
Lord_Flexington
Senior Member
hey man as long as it works thats great! Imma go look on ali express now for that one. Cheapest i found on ebay was 320, so savings is savings. How long did it take you? Imma have to do it on my own as well
__________________
Old 01-22-2018, 08:13 AM   #145
Springer_30
Junior Member
Drives: 2014 PW Golf 7 GTI
You happy with it performance wise? Any logs to share perhaps?
Springer_30 is offline   Reply With Quote
Old 01-28-2018, 04:03 AM   #146
George Ab
Senior Member
Quote:
Since it has been 45į around here, although I am stage 2 I am likely not going to experience heat soak with the stock intercooler so I cannot speak to performance. I will likely find out in the summer. As of right now, it drives like it did before.
Let me know how to set up vagcom (what specific fields to log) to do a log and I would be happy to. I found inlet air temperature, but nothing about intercooler.
Old 01-28-2018, 05:00 AM   #147
AtlantaDad
Senior Member
Not exactly cheap, but looks like Leyo is releasing an intercooler for the MQB platform as well. https://www.leyo-motorsport.com/leyo-intercooler
Now if Burger Motorsports would just hurry up! I need to buy one this Spring before the temps go up.
__________________
Old 01-28-2018, 05:48 AM   #148
marc5800
Senior Member
marc5800's Avatar
Drives: 2016 GTI DSG Autobahn (CDN)
Lol definitely not cheap!
Iím in the same boat. The only realistic option right now is this Magic / Majesty IC since the price isnít insane and it still appears to deliver benefits
__________________
2016 GTI 4 Door Autobahn DSG - Injen Evolution closed intake | CTS turbo inlet pipe | Unitronic catted downpipe | 034 Insert mount | Unitronic Stage 2 ECU tune and BMS JB4 stack
marc5800 is online now   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
