Why aren't your HP & TQ curves crossing at 5252 rpm?
Have you ever tried looking things up yourself instead of making us explain everything to you?
That stunning photo lured me in. Great work on the build - seems quite stable and ready.
Awesome. Love the pic as well.
Also, wow, that is an amazing photo!
A Dynojet figures out HP and then calculates TQ from Horsepower * 5252 / RPM.
At 5252 RPM the HP and TQ are equal since HP is multiplied by 1, something I have seen on my Dynojet results.
So I'm puzzled why this Dynojet is producing different results? What's the answer?
To alleviate the idle vibration (I had the same issue as did some friends of mine with aftermarket mounts) you have to increase the idle rpms.
There are different ways, your tuner can do that as part of the map. If not possible then vcds can increase these by 50rpms (enough for some cars but not all, to help with the vibration). The third possible option (which I will try next week) is to use VCP (vag can pro) which also has an option for increasing idle rpm. Do not know if this works for MQB cars and the max increase allowed, will have to test it when I have my car back in a week or so.
How about looking closer at the graph.
You know, with cutting edge search engines like Ask Jeeves and Bing, we essentially have the sum total of all exigent human knowledge at our fingertips. Which is pretty cool.
But sometimes, my spelling is so bad, I don't even know how to find a word on the internet. Like, the internet has all of the words, and yet, what I write, looks like none of them.
And then there are other times where I am talking to someone who knows what they are talking about, and I'd rather hear it from them than asking a cyber bot. So my point is, if someone asks a question on a forum, and you don't want to answer them, just don't answer them.
It's just a courtesy. Ignore, instead of mock, and the world works better. What I'm saying is, if we treat each other with respect, we can stop snarking each other and get down to the important business of inventing a sex robot that can make an omelette and iron.
Basically most dyno sheets are scaled to allow for the pretty lines to fit on a sheet of paper.
