ManInTheClouds
- OK
Oh man. Do you have to swap your incandescent tails back in again, temporarily?
The previous year, there was no issue with them.
Just a little hitler at this particular place I guess.
Yeah that sounds about right.
For Leuchte27NSL I would code it like the code of the following Leuchte20BR
For Leuchte20BR I would use the code like Leuchte18BLK:
For Leuchte21BR exactly the same as for Leuchte20BR but with “Blinken rechts Hellphase”.
https://www.amazon.ca/Ocamo-Terminal-Electrical-Connector-Extractor/dp/B0755B7WLZ
That should work
One oddity that I noticed. When I press the brakes, the amber signals flash for a split second. However, with either left or right signal active, this does not happen. Happens with or without the running lights on.
Any ideas?
