mroski
- Location, Location, Location
Hi,
I am having trouble diagnosing the problem with my car and would really appreciate your help. Car is a 2014 GTI Mk7 DSG manufactured in Germany.
I am having similar issues to the ones describes in the following post:
http://www.golfmk7.com/forums/showthread.php?t=11370
I need to confirm if the Mechatronic is the problem as to get a new one ASAP as my dealer is not being helpful at all and I've decided to resolve the issue by myself, then I will inmediately trade in the car.
Here is a video of the symptoms:
https://vimeo.com/164113793
After about 3 restarts the car is drivable and runs just fine, even with WOT accelerations.
The errors that have been stored were:
Should I order a new Mechatronics?
HTML:
<iframe src="https://player.vimeo.com/video/164113793" width="640" height="427" frameborder="0" webkitallowfullscreen mozallowfullscreen allowfullscreen></iframe>
<p><a href="https://vimeo.com/164113793">20160416_135006_1</a> from <a href="https://vimeo.com/user51507027">Mroski R</a> on <a href="https://vimeo.com">Vimeo</a>.</p>
Address 02: Auto Trans Labels: 0D9-927-770.clb
Control Module Part Number: 0D9 300 040 S HW: 02E 927 770 AQ
Component and/or Version: DQ250-6F MQB H52 4307
Software Coding: 0018
Work Shop Code: WSC 01357 011 00200
ASAM Dataset: EV_TCMDQ250021 001001 (VW37)
ROD: EV_TCMDQ250021_AU37.rod
VCID: 2757F6FB5E0742061F-8072
6 Faults Found:
21153 - Gear 1
P072C 00 [002] - Not Selectable
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
21155 - Gear 3
P072E 00 [002] - Not Selectable
Freeze Frame:
21159 - Gear R
P072B 00 [002] - Not Selectable
Freeze Frame:
10731 - Valve 3 in Transmission Part 1
P174A 00 [002] - Electrical malfunction
Freeze Frame:
10657 - RPM Signal from ECU
P0726 00 [010] - Implausible Signal
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 0
Fault Frequency: 1
Mileage: 39999 km
Date: 2016.03.11
Time: 00:35:19
10906 - Cooling Oil Valve
P179D 00 [002] - Electrical Malfunction
Freeze Frame:
Address 01: Engine Labels: 06K-907-425-V1.clb
Control Module Part Number: 5G0 906 259 HW: 06K 907 425 B
Component and/or Version: 2.0l R4 TFSI H13 0009
Software Coding: 091D00322424050B3000
ASAM Dataset: EV_ECM20TFS0215G0906259 001013 (VW37)
ROD: EV_ECM20TFS0215G0906259_VW37.rod
VCID: 6BDFCACB826FA666BB-803E
2 Faults Found:
15373 - Sensor Reference Voltage A: Circuit
P0642 00 [167] - Low
MIL ON - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 39999 km
Date: 2016.03.11
Time: 00:35:19
22065 - Implausible Data Received from Transmission Control Module
U0402 00 [039] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 39999 km
Date: 2016.03.11
Time: 00:35:19
