Owenmk7
- Manchester uk
Hello everyone, finally joined after a few years of reading!
Basically my DSG Mechatronics unit let go at 29500 miles, hyd pump failed. Vw fitted new unit (just in warranty, luckily) since having the new one fitted I have covered 1500 miles (enough learning time for new unit), the car continuously fast idles at 1000 rpm.
Vw have had the car 3 days, and they haven't got an answer why it's doing it.
Definitely not a mini regen, happens when car is in D and auto hold is holding the brakes, if I turn start stop off and keep foot on brake pedal, it idles at 800rpm. Feels like the gearbox is advancing throttle as if the auto hold is off, to take up drive!
It does this if engine is hot, cold, alternator under load, everything turned off
Only a small problem but bloody annoying!
