FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Technical Topics > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Reply
Thread Tools Display Modes
Old 06-10-2017, 06:17 PM   #52
Mer2112
Junior Member
Drives: 2017 GTI SE DSG
Mobil 1, 0W-40.
Mer2112 is offline   Reply With Quote
Old 07-13-2017, 10:57 PM   #53
rnewborg
Junior Member
Drives: 2016 Golf R
Just wanted to throw this out there because I haven't seen anyone list it, but anyone try out Redline performance 5W-40 with a MANN filter? Outside the obvious weight differences between 5w40 vs 0w40 please.
rnewborg is offline   Reply With Quote
Old 07-13-2017, 11:05 PM   #54
breaking badly
Senior Member
breaking badly's Avatar
Drives: Winnie Twister
I don't see any correlation between the filter and oil used.
__________________
anything worth doing is worth doing right
breaking badly is offline   Reply With Quote
Old 07-18-2017, 12:34 PM   #55
D'Squared
Junior Member
Drives: VW Golf GTi
what do VW use/recommend?
D'Squared is offline   Reply With Quote
Old 07-18-2017, 12:50 PM   #56
XLYC
Member
Quote:
Quantum in UK
XLYC is offline   Reply With Quote
Old 07-18-2017, 01:24 PM   #57
breaking badly
Senior Member
what do VW use..?
From factory:
- Shell Helix Ultra Professional AV-L 0W-30 VW 504 00/507 00 (= Pennzoil Platinum EURO LX VW 504 00/507 00)
- alternatively (depending on engine type) Castrol Edge 5W-30 VW 504 00/507 00
- starting week 22/2017 some lower viscosity 0W-20 VW 508 00/509 00 on European market Golfs (no details yet)
I know US spec GTIs, Golfs and Rs only require VW 502 00. However 502 00 is a
dirty old spec.
VW 504 00 is newer AND higher demanding = better. That does NOT necessarily
mean that any 504 is better than any 502 oil, but it actually does mean that any
oil meeting VW 504 00 spec is a very very proper oil, better than 'some' 502 00
oils at least, if not most.
Again, there is no 'best oil' out there. Use a proper one and enjoy your car. I'm
going to use the above mentioned Shell/Pennzoil 0W-30 and swap every 10 Mm.
__________________
Old 07-18-2017, 01:26 PM   #58
nofuiyo
Junior Member
Drives: 2017 VW Golf Wolfsburg
I use Schaeffer's 8008 Advanced European Performance Mid SAPS 5W-30 on my 2017 TSI (VW 502.00/505.00 approved and suitable for VW 504.00/507.00)... I don't drive it hard (between 70-80 mph on the highway) and it is not tuned. I check the oil level every week and mine does not burn oil. The Castrol it came with from the factory burned oil and I had to add 1/4 of a qt at 4,000 miles; I did the 1st oil change at 5,500 and put the Schaeffer's and have not looked back. Very happy with it. I am sitting at 17,200 right now; 2nd oil change was done @ 12,6xx
nofuiyo is offline   Reply With Quote
Old 07-20-2017, 06:41 PM   #59
Gibberoni
Senior Member
Drives: 2015 GTI SE (LP)
Chiming in: LiquiMoly 5W-40
__________________
BFI Alcantara Heavyweight Shift Knob | ECS Bleeder Block | AWE Track Catback Exhaust | 034 Dogbone Mount | More to come...
Gibberoni is offline   Reply With Quote
Old 08-11-2017, 07:21 PM   #60
surfstar
Member
Drives: 2016 GSW TSI S 5MT
Just stocked up on a couple more jugs of M1 0w40
$22.88/5qt at WalMart.com, $12 Mobil rebate, limit 2
There is no objectively "best" oil, but there is a cheapest
:-D
surfstar is offline   Reply With Quote
Old 08-19-2017, 08:51 PM   #61
seanmcd
Member
Drives: 2016 GTI Autobahn
Liqui Moly Leichtlauf High Tech 5W-40
OEM VW filter
seanmcd is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
