mattkime
- madison, wi
Preparing for install!
I watched this video and I'm feeling a bit more comfortable - https://www.youtube.com/watch?v=84rsMrtoztc
I have a JB4 with the wireless connector installed. I have the iOS app installed.
I'd like to confirm the following:
1) I need 91 octane (93 is whats available here) in the tank
2) It should default to map 1 - although i wish I could verify this before install
3) map 6 is custom - what about all the other maps? what are they for?
4) I should grab a couple of posi-taps. Which gauge?
5) ODB cable. Does it do anything I need? I suspect not.
After install, I should drive it for a bit and make sure everything is working well. Then I can consider increasing boost.
I took a look at the iOS app. It looks like a lot of setting are either ignorable OR something you'd revisit after some experience.
Does this sound like a reasonable plan? Could an experienced JB4-er or two weigh in?
