I was confused by that too! Lol But isn't the is38 more fragile to blowing? I haven't really read of very many newer style is20's blowing up.Lol I did use the word turbo. Stress on the turbo. Yes sir Turbo. And if you went with the “latter” regarding you’re own question, wouldnt that be engine?? Lol
Im confused. But what I MEAN, is less stress on the oem is20 ihi turbocharger
Yeah I'm not a fan of how it shifts higher in the upper rpms now under light throttle. I find myself manually shifting all the time to drop the rpms when cruising. It doesn't need to sit and rev @ 2100 rpms at constant speeds. Mine seems to shift @ 2300 rpms. No matter what speed under normal driving conditions.Anyone able to tweak a dsg file? I’ve noticed the shift latency is load based , looking to improve the shift speeds under light load (quarter to half throttle) similar to that of full load (three quarter to full throttle).
Idk. I don't know much about the jb1. George was working on firmware for me to use were the jb4 can control meth without being plugged in and without adding boostWouldn't the original jb1 control meth the same way as the jb4 just without the afr tap and use of the obd port?
I probably got too wordy...I was confused by that too! Lol But isn't the is38 more fragile to blowing? I haven't really read of very many newer style is20's blowing up.
Check out this thread for the throttle delay: http://www.golfmk7.com/forums/showthread.php?t=32578Hi all!
I got a noob question:
I'm about to get ED's tune, but I'd like to know if it will get rid of the annoying drive-by-wire throttle delay that VW in its great wisdom has decided to plague my ECU with. It's driving me crazy when trying to put power down exiting corners, it's just like the retarded clutch delay valve, but that was an easy fix..
After going through a couple hundred pages of this humongous thread I haven't seen any mention of this and, although I'd like to get through the whole thread, it might take me a few months
Thanks to anyone who'll take the time to reply.
Does that help with the launch control delay? Any side effects to doing that?
So it's not really even worth doing then?
So I just purchased Meastro for my A3.
I've used it in the past and don't really have any questions for my engine tune, but man am I hearing conflicting DSG tune reviews. The price point sure seems cheap, but I'm curious on user opinions of their DSG tune.
