FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Technical Topics > Exterior / Interior Care (washing, detailing, exterior repairs)
Reply
Thread Tools Display Modes
Old 02-12-2018, 03:21 AM   #1
Fast Medicine
Member
Drives: 2015 GTI SE w/PP UNI IS38 FBO
Fuse for Left DRL GTI with lighting package
My car gave me a message today that the left DRL needs to be checked. What is the fuse number / location of the fuse ? Figured I would check before going to the stealership. Thanks
Fast Medicine is offline   Reply With Quote
Old 02-12-2018, 06:23 AM   #2
Fast Medicine
Member
Anyone ?
Old 02-12-2018, 07:49 AM   #3
NeedSleep
Senior Member
NeedSleep's Avatar
Drives: 2017 GTI Sport DSG
I found this fuse chart somewhere before, but can't remember who posted it. I hope it helps http://cloud.tapatalk.com/s/5a8138f3...e%20Layout.pdf
NeedSleep is online now   Reply With Quote
Old 02-12-2018, 12:11 PM   #4
Fast Medicine
Member
Thanks !!!
Old 02-12-2018, 04:29 PM   #5
dawooj
Junior Member
dawooj's Avatar
I had the same warning msg a couple months back. My passenger side LED DRL was out. The control module had to be replaced by the dealer, but it was done under warranty.
Did you notice any moisture inside the headlight housing? I think condensation caused mine to fail.
dawooj is offline   Reply With Quote
Old 02-12-2018, 05:35 PM   #6
NeedSleep
Senior Member
NeedSleep's Avatar
Condensation inside the headlight and taillight housings is normal for these cars. If your DRL went out, it was likely just part of a bad batch
Sent from my SM-G900T using Tapatalk
Old 02-15-2018, 04:10 PM   #7
Fast Medicine
Member
It was a control module, I was days from being out of warranty. $900 I’m glad I didn’t have to pay
Old 02-15-2018, 04:30 PM   #8
dawooj
Junior Member
dawooj's Avatar
While it's a common enough occurrence, I wouldn't exactly call it normal. It's a result of something in the housing-usually a pinched gasket-forming an improper seal.
When my LED DRL failed, it was on a day with heavy rain. I noticed the side that failed had condensation on the inside of the housing, while the good side did not. It could just be a coincidence, but usually, moisture and electronic parts don't mix well together unless they were designed for it.
Old 02-16-2018, 12:37 AM   #9
NeedSleep
Senior Member
NeedSleep's Avatar
It's normal and even stated in the manual. The lights (headlights and tail lights) have small holes in the housing, where even bugs/insects can get inside.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
