worldacgti
Quick question guys, will a bad map sensor always trigger a code? I think mine is causing my boost issue bu I am not getting any codes....any help would be appreciated. The car will try and hit (in my case around 25-27 psi) and then cut out for a split second and proceed to pull. Also, the car is running pig rich, around 10.8-11.3 afr at wot. Side note, i got the apr pops and bangs map and thought that might be the issue. It is not as i flashed back to reg stg 2 and problem persists...
