Nutztoys, were you not able to shove the assembly down at all before you started jacking it up? What did you use to spread the knuckle?
Anyway, glad it worked and thanks for the input. Just curious.
Hey Guys,
Fitted my VWR springs today using the 2x4 method.
To prevent the lower control arm to come up when you Jack up the 2x4, I used a strap underneath the floor Jack.
Just my 2 cents....
Similar to what this guy did on his Golf R]
Would this kit be sufficient or would I be spending too much money?
https://shopdap.com/store/catalog/p...uspension-install-kit-complete/category/4609/
I received my Bilstein B12 pro kit in the mail and everything looks great. Since I have never done suspension work before I want to make sure I have everything I need. I already ordered all the replacement hardware suggested here, but I am missing one thing. The Front Lower Spring Isolator Part Number: 5Q0-412-545-D
https://shopdap.com/store/5q0-412-545-d.html
If I drop the springs into the dampers now they sit at an angle and are metal on metal, obviously not how its going to be installed. My question is, do we just reuse these from the stock springs, or do I need to order a set for my new springs? I am sure the rubber isolator will make everything sit perfectly. Just want to make sure I have everything before attempting install.
Awesome! Thanks!^ You will just reuse the ones you have. [emoji106]
