FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Technical Topics > Cosmetic Mods (interior & exterior modifications)
Reply
Thread Tools Display Modes
Old 02-17-2017, 08:48 AM   #1
Derushi
Senior Member
Drives: PP/LP 6MT
Drilling through pedals?
Has anyone here changed their pedals? I'm looking to install a set of aftermarket pedals and wanted to make sure that it's okay to drill through the pedal backing.
http://imgur.com/a/CBRju
There isn't really any room to drill and mount through the sides so I figured I'd just drill through the thick pedal backing if it wouldn't cause any issues.
(The brake and throttle pedal covers were a pain in the ass to remove lol)
__________________
Stock-ish
Build thread
Derushi is offline   Reply With Quote
Old 02-17-2017, 02:04 PM   #2
jmason
Member
Drives: 2015 GTI S 4 Door 6MT Night Blue Metallic with LP
I removed the stock pedal covers and installed Awe Tuning covers. The only difficult pedal to drill thru is the brake pedal because it is metal; the others are plastic. I used a right-angle drill because I couldn't get a straight drill at 90 deg to the pedal. I also offset the gas pedal, moving it closer to the brake to facilitate heel-and-toe.
__________________
3M Crystalline 50% tint | P3 Cars VIDI Display | VWR Sport Springs | Michelin PSS 235/40 | Euro-Spec Aspherical Mirrors | Cross-Drilled and Slotted rear Rotors | Short Shift Kit | Tyrolsport Deadset | BFI Catch Can | Neuspeed REs12 18 x 8 Bronze | Eurocode Adj F & R SBs | SuperPro End Links | BFI Weighted Shift Knob | AWE Tuning Performance Pedal Covers | Brembo 330mm BBK | Solid Shifter Bushings | SuperPro Alloy FCA
jmason is offline   Reply With Quote
Old 02-17-2017, 02:37 PM   #3
Lord_Flexington
Senior Member
Lord_Flexington's Avatar
Drives: '15 GTI LP PP|'01 CBR 929
I cant find new pedals anywhere. I hate the stock ones. So damn slippery all the time. I use grip tape on them right now
__________________
2015 GTI S PP//JB1//DP//INJEN CAI//GFB DV+//VMRV705//VWR SPRINGS//PZERO ROSSO//SPULEN SS//RACESENG//OBD11//Deep Pearl Gang//BIG WANG GANG
P1 GTI TCR-->http://www.golfmk7.com/forums/showthread.php?t=25994
Lord_Flexington is offline   Reply With Quote
Old 02-17-2017, 05:08 PM   #4
Derushi
Senior Member
Drives: PP/LP 6MT
Yep, agreed. The stock pedal covers are really slippery if your shoes are wet. The pedal placement also doesn't make it any easier to heel/toe.
Quote:
Thanks for this! I'll try and drill through the pedal backing, they're quite thick but as you said, they are plastic. Hopefully my drill can punch through the metal brake pedal.
Do you have any pictures of what your pedals look like?
__________________
Stock-ish
Build thread
Old 02-17-2017, 07:41 PM   #5
jmason
Member
[IMG][/IMG]
Ok, I'm embarrassed by the dirt! As I mentioned, I offset the gas pedal cover to move it closer to the brake pedal. You can see a bit of the OEM gas pedal sticking out beyond the Awe pedal cover on the bottom right corner.
__________________
Old 02-17-2017, 07:42 PM   #6
Derushi
Senior Member
Drives: PP/LP 6MT
Looks good! I'll be installing my SRP set hopefully this weekend. Mine's super dirty as well lol.
__________________
Stock-ish
Build thread
Old 02-17-2017, 08:22 PM   #7
2015WhiteGTI
Senior Member
Drives: 2015 VW GTI
I drilled through my BMW pedals to install aftermarket covers and like others have said, the brake pedal is the hardest since it's metal and the others are plastic.
I marked the placement of the holds and then used a drift pin and hammer to put a mark in the pedal where I wanted to drill. This helped the drill bit from "walking" when I started drilling. I pushed the pedal down to the floor by wedging a 2x4 between it and the under side of the dash. It held in place nicely and game me enough room to put good pressure straight down on the drill. Once the drill took a bite, it went through with ease.
__________________
2015 GTI S, 6M, LP, Volk TE37SL 17x8.5, Michelin PSS 245/40, HPA SHS Coil-Overs, Peloquin LSD, Sachs SRE, Eurocode F/R Sway Bars, SuperPro Control Arms, Remus Catback, APR Stage 1 Tune, APR CAI, Aero Force Gauge Pod, APR Boost Gauge, Kersher Front Lip, Short Shifter, Tyrolsport Deadset, 034 Insert, A/S3 Aluminum Subframe
2015WhiteGTI is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
