FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Technical Topics > Golf Engine / Drivetrain / Exhaust / Tunes
Reply
Thread Tools Display Modes
Old 03-20-2017, 05:42 PM   #1
Jondar
Senior Member
Jondar's Avatar
Drives: MK7 Silk Blue 1.8T SE
Excessive engine vibration/movement
I have recently been having a lot of engine movement while reversing and I didn't think about it too much at the time, but now it is happening more frequently. It is also happening now while I am driving forwards. Usually while idled at a stop sign/or light, as soon as I accelerate normally I get a few engine kicks (This does not happen all the time).
The best way to describe the movement is as if the engine were jumping.
I tried to isolate some recent modifications that I've done that possibly have something to do with the issues I am experiencing.
1. Unitronic Stage One
2. I tried to install 034 type 1 insert but couldn't fit it, I didn't have a rubber mallet at the time so I decided to put off the installation. In doing this, I couldn't get the factory mount screw back in because a few layers of the mount/frame weren't aligned. I had to pull/push all the layers together to fit the screw back in. - I am thinking this is probably the reason why I am experiencing heavy vibration, but I can't be sure.
3. Another possible reason; I was using tiptronic (I have an auto), and like a dyslexic scrub, I was downshifting instead of upshifting and the car stalled for a few seconds, while also losing power. EPC and check engine light came on and I had to park, power down and restart. As soon as I got home I plugged OBDeleven to see if I could troubleshoot the issue, couldn't find anything so I cleared the errors and proceeded to baby my car for the following week. I don't know if this could even be related to the issue I am having - but full disclosure.
Has anyone experienced anything thing like this?
Jondar is offline   Reply With Quote
Old 03-20-2017, 06:24 PM   #2
skinnyroots
Senior Member
Drives: '16 1.8T
My guess is that it has something to do with your attempted installation of dogbone insert.
__________________
2016 Golf TSI - 1.8T - Unitronic Stage 1 - OEM Lowering Springs - 034 Dogbone Insert - 18" OEM 'Topas' Wheels - Bridgestone Potenza RE760 - ECS Tuning CF Mirror Caps - Dynablink Turn Signals - 35/20% Tints - Euroswitch w/ Auto Light Sensor - Pure White
skinnyroots is offline   Reply With Quote
Old 03-20-2017, 06:26 PM   #3
Finglonga
Senior Member
Finglonga's Avatar
Drives: Mk7 Golf GTI Performance
You don't need a mallet to insert the 034 insert, if it does not slip in then you have the wrong one. Have you checked the bolt has not fallen out?
__________________
Finglonga is offline   Reply With Quote
Old 03-20-2017, 06:29 PM   #4
Jondar
Senior Member
Jondar's Avatar
Quote:
This is what I am hoping it is, as it is the easiest fix. I may just take it in to a shop just to be sure. - Thanks for the reassurance.
Old 03-20-2017, 06:41 PM   #5
Jondar
Senior Member
Jondar's Avatar
Quote:
My initial thought was that it would slip in, but it's a bit tight (No sexual innuendo intended). After triple checking the mount, it is indeed the correct insert. I am able to fit the insert, but bolting it on is where I run into trouble. It doesn't seem to align right where I can screw in the bolt all the way. The whole process using force seemed a bit iffy to me, so I decided to not install it. I'm thinking I have to tighten the bolt a bit more, however I don't have any means to measure ft/lbs. I am hoping I didn't screw up the mount in the process. - Worst case scenario I will just change out the whole lower engine mount.
I thought it would be a lot more obvious if the bolt fell out, but there's only one way to be sure.
Old 03-20-2017, 07:38 PM   #6
MeltedSolid
Senior Member
MeltedSolid's Avatar
Drives: Mk7 Golf TSI Launch Edition
Quote:
This baffles me... It should be impossible to downshift where it's not safe with the auto (at least it was with my mk6), but you even got a check engine light and EPC! I don't know how you managed to pull that off!
Anyways, did you make sure to reinstall the dogbone bolt with a torque wrench to the proper spec? If not then it's probably that.
EDIT: I just read the above post. If you have an autozone near you then you can borrow ("rent") a torque wrench from them for free. If you can't do that find somewhere/someone with a torque wrench and borrow it. I believe the correct torque spec is just under 100ftlbs, so you'll really need to crank it down.
__________________
2015 TSI Launch Edition | Deep Black | 5-spd manual | APR Stage 1 + JB4 + IS20 swap | DIY Turbo Muffler Delete | 17" Enkei RPF1's | 034 dogbone insert V1 | BC Racing BR series Coilovers | ST 25mm rear sway bar | DIY HD Clutch Stop | NGK RS7 Spark Plugs | VWR Catted Downpipe
MeltedSolid is offline   Reply With Quote
Old 03-20-2017, 08:55 PM   #7
Jondar
Senior Member
Jondar's Avatar
Quote:
Normally I believe with auto/tiptronic, it helps you out if you are being and idiot and will upshift for you. However, I was punching it, meanwhile downshifting like a mad man because I was wondering why the gear wasn't changing. When I came to realization it was already too late, the car starting stalling. Incredibly dumb and embarrassing. I've sort of done this before, but it wasn't as dramatic, and the car shifted for me. I can't help but to think it may of been due to the tune.
Going to do this today and see this eliminates the issue. - Thanks for suggestion.
Old 03-20-2017, 10:18 PM   #8
MeltedSolid
Senior Member
One of the most annoying things about the tiptronic was that the shifting is backwards :P.
__________________
Old 03-21-2017, 12:14 PM   #9
TwinDad
Senior Member
Drives: 2016 sportwagen
What is it backwards compared to? I grew up with TH400 and TH350 transmissions. Unless you went full race on the thing and put in a reverse valve body, it was first all the way back. Then you pushed forward to upshift for second and third. Ford and Chrysler did it the same way. This is my fourth tiptronic and I never had issues or made a mistake. BMW does it the other way though. You push forward to downshift. I would screw that one up all the time.
__________________
2016 GSW- JB4-IS20-e30-RS7 plugs-Piggie pipe-K&N drop in
TwinDad is offline   Reply With Quote
Old 04-03-2017, 07:36 PM   #10
Jondar
Senior Member
Jondar's Avatar
Update:
Torqued the mount bolt to 100 nm per specifications and I am still having the same issue; just a bunch of motor movement while reversing.
Old 04-13-2017, 12:09 AM   #11
Jondar
Senior Member
Jondar's Avatar
Fixed:
Tightened the bolt using 130 NM. No more sick motor hops. Still can't figure out why the insert wont fit, it is definitely the correct version.
Edit: specs
Old 04-13-2017, 01:30 AM   #12
Reggie Enchilada
Senior Member
Drives: MK7 GTI
That's almost twice the factory torque spec....
RIP dogbone mount threads
__________________
2016 GTI 6MT: ED Maestro Stg2 base, E30, Brisk ER12S plugs, Bull-X catless DP, Forge CF intake, CTS TIP, Uni IC, CTS charge pipes, Boomba BOV, ECS boost tap, Revo drivetrain mounts, Stg3 BFI clutch, ECS bleeder block, ECS SS clutch line, Boomba shift knob, APR short shift levers, ECS brass shifter cable end link bushings, ECS aluminum shifter cable bracket bushings, O34 spherical end-links, ST RSB, ECS skid plate, deAuto 6000k HID low beams, Nokya 3000k halogen high beams
Reggie Enchilada is offline   Reply With Quote
Old 04-13-2017, 01:54 AM   #13
sethdude
Senior Member
Drives: GTI Sport DSG
If you downshifted to over-rev (which should be impossible), its very likely that the drivetrain jerked hard enough to damage the transmission mount. That's probably why the bolt wont fit. I can't imagine hammering the Tiptronic enough to cause the car to stall. You should probably drive a bit more calmly going forward.
sethdude is offline   Reply With Quote
Old 04-13-2017, 04:23 AM   #14
Jondar
Senior Member
Jondar's Avatar
130 NM is what I actually did. Checked the torque wrench. The initial torque spec I used was 100 NM, and there was still a bit movement.
Old 04-13-2017, 04:27 AM   #15
Jondar
Senior Member
Jondar's Avatar
Quote:
To be honest I'm not all sure what went wrong. There were a few variables as to why it could of stalled. I had a OBD in reading boost during all of this, it may of been interfering with the computer.
My main issue is I am not able to actually fit the mount, it doesn't go in enough to even hold. When I press the insert against the mount and look into the bolt hole, the mount and dogbone are not aligned. Which is the reason why the bolt won't go in. Without the insert the bolt goes in just fine.
Reply
Tags
movement, vibration
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
