Did some research and it seems the clubsport s swivels are the same as the audi TT ones.
The front of the clubsport s is made of:
Audi a3/s3 tt aluminium subframe
Swivels bearings audi tt
brake discs with aluminium hat
What about the control arms are they aluminum?
And also can someone with the latest etka check if the steering rack, tie rods and tie rod ends are the same as a regular gti/r
If they are the same we can fit the tt swivels without any problem
You can very most probably fit CSS swivels without any issues,
as long as you use TT wheel bearings with them. I don't think
these swivels are TT parts though since they use a 5Q number
instead of 8S numbers.
Unfortunaty CSS control arms are still pressed sheet steel. The
only difference to the standard Golf control arms are their solid
rubber bushings. The same applies to the CSS rear control arms.
On a quick look they look the same as standard.
To my current knowledge, steering rack is the same as on any
GTI/GTD/R (progressive steering). Bear in mind different swivels
could alter steering ratio if the length of the 'steering arm" is
somewhat different. This has been the case on the former PQ35
platform, where S3 swivels made a slightly shorter steering ratio
compared to Golf. Well, currently we only know about the added
camber.
I did that for you and all those interested:
I think springs and and roll bars shouldn't be as interesing since
most prefer aftermarket parts anyway. On the regular Clubsport
(non-S) these components even more are depending on gearbox,
door count and equipment. It's little too complex to list them all.
