I have removed the heat shield this morning as per recommendations from others to cope with some drone between 65-70 mph.
Sent from my SAMSUNG-SM-G890A using Tapatalk
How are you finding exhaust sounds in cabin after heat shield removal?
It did make a difference. It doesn't resonate inside as bad as it was before going 60-70 MPH. I even measured the dB with a sound meter over the same stretch of the road going to work. The dB's were lower which what I was hoping for.How are you finding exhaust sounds in cabin after heat shield removal?
I wouldn't remove the resonator as others said it becomes way too loud. Muffler delete sounds like having an aftermarket exhaust but for the fraction of the cost and the process is reversible.
thanks for that.I think the resonator weighs about 20ish lbs, so probably at least 15 saved. It's a lot of hollow space.
Yes, I wouldn't do muffler delete ever again. Either invest in a proper catback or get a downpipe. These 4 cylinder engines sound like shit. I had muffler delete, then downpipe and res delete, then APR turboback and finally found a combo I can live every day with which is APR downpipe paired with non-resonated midsection Remus catback.Bringing this thread back from the dead. Planning on doing a muffler delete with center exit. Just to confirm, this is 4" tips w/ 2.25" inlet?
Now that some time have pasted. Would you do anything differently?
