ECS Tuning
- Wadsworth, OH
The factory Gen3 plastic charge pipes and rubber couplers were never designed to handle the stress of higher boost levels much beyond stock, making them a weak point for modified vehicles.
At ECS Tuning, we're proud to release our in-house designed and engineered High Flow Turbo Outlet Pipe Kit! Each kit comes standard with high-quality wrinkle coated aluminum piping and 4-ply silicone couplers. Each piece is designed as a direct replacement so installation is easy and requires no modification.
Key Features:
- Reduces turbulence and increases air flow capacity
- Gains up to 10 WHP & 10 FT-lbs of torque with APR Stage 2 93 octane software, 3.0" Milltek turboback exhaust and ECS Kohlefaser Luft-Technik Air Intake with our High Flow Turbo Outlet Pipe Kit and Throttle Pipe Kit (Gains measured on MK7 Golf R)
- Mandrel bent and bead rolled aluminum tubing, powder coated in tough wrinkle black or wrinkle red finishes
- Replaces all rubber hoses from turbocharge-to-intercooler with 4-ply silicone upgrades
Cooler, Stronger, Better.
Click HERE to order or for more information
https://www.youtube.com/watch?v=cPP5qwIEcnI
VW MK7 GTI (2015+)
VW MK7 Golf R (2015+)
VW MK7 Golf 1.8T Gen3 (2015+)
VW Alltrack (2017+)
Let me know if you have any questions.
Jason
