Agray
- Washington
Only if the pipe breaks loose from the filter because it's not seated properly.
Can't see that happening... It's clamped pretty good.
5 minutes. Just do it while cold so the coolant drained down. But shove a towel down there when the do the one on the engine.
I could be wrong but I feel like there is a one way valve in the stock one.
IE Carbon Fiber Intake and Turbo Inlet pipe. Purchased used off of this forum for $500 and I love it.
Keep it simple and cheap
Keep it simple and cheap. Throttle response and spool is terrific btw. .
Are you running without the front inatke piece and just the separate scoop on the airbox? If so, does it feel slower off the line?
Thanks.
Thanks.
Just remove/unbolt the entire horizontal (left to right) front intake straw. It comes out and leave the scoop on front of box. Then pop out your grill (two screws) and open up the top left side (dremel, drill, saw) to allow more direct air from grill to come up into box.
Slower...hell no. Your turbo will thank you. .
