FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Volkswagen GTI / Golf MK7 General Topics > Golf R Discussions
Reply
Thread Tools Display Modes
Old 04-16-2018, 03:47 PM   #1
VW1
Junior Member
Drives: 2017 Golf R
Bad oil change
(2017 R) Less than ideal oil change at the dealer this weekend. Long story short, after driving the car home, noticed a trail of oil - about 12 miles. After the car sat in the garage for a few minutes, a dinner plate + sized puddle formed. The car holds 6 qts, and after adding the only 2 extra qts I had, it brought it to the bottom of the measuring area of the dipstick, I estimate it arrived home approx 3 qts low. Car sounded normal, no low pressure warning lights, oil temp normal. Had it towed back to the dealer and apparently a bad O ring around the filer is to blame. I would imagine these engines can tolerate a low oil situation, but was wondering if anyone could share their similar stories with me and the outcome. Car still resides at the dealer awaiting a thorough cleaning and check it ensure all is well. Any suggestions on what I might consider requesting the dealer to check would also be helpful.
VW1 is offline   Reply With Quote
Old 04-16-2018, 04:06 PM   #2
BravoMike
Senior Member
BravoMike's Avatar
Drives: Mk7 GTI S w/PP, DCC, LP, 6MT
Bad o-ring around the filler? Did you open the hood? With that much oil missing it would make a huge mess wherever it was leaking.
Stories like this are why I change my own oil. I had a friend who took their car in and they only hand tightened the drain plug. Forgot to put a wrench to it. As my friend was driving home, the drain plug vibrated out and lost all oil. I think many shops see this routine maintenance so many times that they become complacent.
__________________
NewSouth VentPod Boost Gauge Kit||| Enkei Fujin |||Bridgestone RE-11||| VCDS - ESC OFF ||| VW Aspherical Mirrors||| 24mm H&R RSB ||| AWE Track Catback ||| 034Motorsport Aluminum Dogbone Insert||| ECS Shifter Bushings |||ECS Clutch Bleeder Block ||| OEM Short Shifter ||| Cobb MAPerfomance Stage 1
BravoMike is online now   Reply With Quote
Old 04-16-2018, 04:32 PM   #3
VW1
Junior Member
Drives: 2017 Golf R
Bad O ring is what I was told. I agree and should probably do these myself in the future. Pics attached.
Old 04-16-2018, 05:17 PM   #4
BravoMike
Senior Member
BravoMike's Avatar
Quote:
There is an o-ring on the filler cap and the oil filter housing. I have no idea how these could be bad. Sounds like someone may have goofed.
FWIW, this is the easiest car that I’ve done oil changes on.
Also, pics aren’t showing for me.
__________________
Old 04-16-2018, 05:28 PM   #5
M3bs
Member
Drives: 95 S54 M3 track toy, 2016 LSG Golf R
More likely the o-ring on the drain plug, which doesn't require torquing. I'd be suspicious they didn't get the plug latched in properly. Your dealer must be really talented. It's hard to do it wrong!
M3bs is offline   Reply With Quote
Old 04-16-2018, 05:35 PM   #6
Finglonga
Senior Member
Finglonga's Avatar
Drives: Mk7 Golf GTI Performance
The Filter O ring would not leave a trail of oil along the road it would coat everything in the engine bay with oil before that happens. As others have said sounds like the drain plug O ring was missing.
__________________
Finglonga is offline   Reply With Quote
Old 04-16-2018, 05:47 PM   #7
VW1
Junior Member
Drives: 2017 Golf R
It was definitely from the cartridge canister. Although I am mechanically inclined, I have not previously changed the oil on this car previously. I watched a few you tube vids and it obviously VERY easy. Spoke with a local VW performance shop and their opinion is its probably fine. Unbeknownst to me, the oil pressure warning light provides its warning based upon the presence of air in the pick up tube from the oil pump and is very sensitive. Therefore, if the system was pumping even the slightest amount of air, you'd get a warning. The fact I never received a warning means oil was still circulating. Their further opinion on the leak itself was the tech probably rolled the O ring or didn't lubricate it. Still waiting on hearing from the dealer. I'll try to get the pics posted again.
Old 04-16-2018, 05:54 PM   #8
Abilor
Junior Member
Drives: Hyundai Accent
Sigh. Stealerships.
Abilor is offline   Reply With Quote
Old 04-16-2018, 06:25 PM   #9
nate704
Senior Member
Drives: 2017 R
That's why I don't trust those "TECHS" at the dealers.
nate704 is offline   Reply With Quote
Old 04-16-2018, 06:56 PM   #10
Golfs everyday
Member
Drives: 16 GTI & 17 Golf-R
Wow horrible! Did you not smell smoke while driving the 12 miles?
__________________
DD: 2016 GTI Autobahn DSG l Weekend: 2017 Golf-R MT
Golfs everyday is offline   Reply With Quote
Old 04-16-2018, 07:05 PM   #11
ztorc
Junior Member
Drives: 2018 Golf R DSG and 370Z MT6 Driver
You should post the dealer name.
ztorc is offline   Reply With Quote
Old 04-16-2018, 08:17 PM   #12
dragonskiss
Junior Member
Drives: 2017 Pure White GTI Sport 6MT
Quote:
^This.
dragonskiss is offline   Reply With Quote
Old 04-16-2018, 08:33 PM   #13
Hoon
Senior Member
Hoon's Avatar
Drives: '17 GTI Sport DSG
There's probably another quart in your alternator.
__________________
FBO / IS38 / Stratified
Hoon is online now   Reply With Quote
Old 04-16-2018, 08:48 PM   #14
southpawboston
Senior Member
southpawboston's Avatar
Drives: '17 GSW S
Quote:
They assign the simple jobs like oil changes to the least experienced techs. If you had an "in" with the service department, you might be to arrange for only more experienced techs to ever touch your car, but it's unlikely that the experienced techs would even want to do routine work like that.
__________________
OBD mods
past VAGs: '69 Type 3 Variant • 1984 GTI • '85 Scirocco Wolfsburg Edition • '86 Scirocco • '86 Audi 4000S
southpawboston is offline   Reply With Quote
Old 04-16-2018, 09:43 PM   #15
Firstboost
Senior Member
Firstboost's Avatar
Drives: Intrepidus Cuniculus
Damn man that sucks. I hope that dealership will be paying to clean your engine bay and under carriage for this error.
__________________
2016 Oryx Golf-R - Peter Cotton Tail - APR Stage II HT | AMS DP | AMS intercooler | Integrated Engineering intake w/ inlet pipe | 034 dogbone | APR SS w/42DD | iABED rear main seal | Fluidampr | ED |
Firstboost is offline   Reply With Quote
Old 04-17-2018, 12:20 AM   #16
Urlik
Senior Member
Drives: Golf 7R
Quote:
They usually aren't even actual techs.
Urlik is offline   Reply With Quote
Old 04-17-2018, 12:46 AM   #17
SouthSideGti
Member
SouthSideGti's Avatar
Drives: 2015 GTI Autobahn
There are three places I take my car in Washington for maint.
1. Achtuning
2. Auburn VW
3. Ballard (Carter) VW
lets hope 2 or 3 didnt do your oil change
__________________
2015 GTI Autobahn Carbon steel Grey // AWE Touring Edition Catback // VMR 801 Hypersilver 18x8.5 ET45 // Hankook V12 Evo2 225/40 // Vogtland Coilovers // H&R Sway Bars // APR Intake & Charge Pipe // APR Stage 1 High Output Tune // MK7 Euro Tail Lights // P3 Gauge // OBDEleven Available (Seattle Area)
SouthSideGti is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
