Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Marketplace > Vendors Classifieds > General Sales/Announcements
Old 06-11-2015, 08:08 AM   #1
deAutoLED.com
deAutoLED.com's Avatar
Drives: VW
Color Changing Footwells on sale now! Change to any color with a click of a button!
http://deAutokey.com/product/mk7-gti...-footwell-leds
https://www.youtube.com/watch?v=7bEO7nfcGhs
**These are plug and play LED bulbs with IR sensor so you can remotely change your footwell color at anytime. This will fit in any MK7 with a footwell housing installed.
This is NOT a strip of LEDs, these fit directly into your OEM Footwell housing and will replace your current footwell bulb.
You can change your footwells to any color including:
-White
-Red
-Dark Blue
-Light Blue
-Green
-Light Green
-Orange
-Yellow
-Purple
-The color you choose is stored in memory, meaning these will be the same color as you previously selected before you shut off your car.
example: if you choose blue, and shut off your car, the next time you turn on your car, the color will be blue.
-You can have a solid light, strobe, fade, and flash through all colors or just one, all while choosing different speed settings for each mode.
-Easy to use and read remote (actual remote you will receive is pictured).
-Controller will control footwell that the remote is pointed to, meaning you can have 2 different color footwell options, ie: driver side blue, passenger side red. Or they can match.
-Without the remote these will act like your regular footwells, powering on when your car unlocks.
-You can adjust the brightness levels from 1-100% with a click of a button, brightness % is remembered for the next time you turn on your vehicle.
Kit contains: (2) LED Changing Bulb (1) Remote
Error Free
Direct Plug & Play
Lifetime Warranty
Free Shipping
http://deautokey.com/category/leds-for-mk7-gti-golf <- NEW LEDs for your MK7!
Footwell LEDs | Reverse | License Plate LEDs | Brake LED + MUCH MORE!
Like us on FB for LED updates: www.Facebook.com/deAutoLED
deAutoLED.com is offline   Reply With Quote
Old 06-11-2015, 12:18 PM   #2
dc22
dc22's Avatar
Drives: 2015 GTI
Ordered! Do you by chance have a video or pictures showing where the factor bulbs are located for the install? Shouldnt be difficult to find but figured I would ask.
dc22 is offline   Reply With Quote
Old 06-12-2015, 02:14 AM   #3
deAutoLED.com
Drives: VW
Yes, it is out in the open you will see the plastic housing, if you ordered our 4pc tool kit then there is a tool in there that will pop out the footwell housing effortlessly. If you don't, you can try to use something that can get in between the carpet and footwell housing - there is a metal tab holding it into place you have to push in and then pull downward.
Let us know if you have any questions
Old 06-13-2015, 08:24 AM   #4
deAutoLED.com
Drives: VW
Thanks for the orders - these are going quick at the sale price!
Old 06-23-2015, 11:51 PM   #5
deAutoLED.com
Drives: VW
https://www.youtube.com/watch?v=ko1nnEp3W0Q
Old 06-26-2015, 06:58 PM   #6
deAutoLED.com
Drives: VW
Thanks for the orders!
Old 07-01-2015, 05:18 AM   #7
deAutoLED.com
Drives: VW
A summer must have.
Old 07-17-2015, 09:06 PM   #8
elamothe15
Drives: 2015 VW GTI S Manual
These lights look awesome! When I first bought my GTI I was even thinking about changing the footwell light color. Did you happen to get yours installed yet? How are they?
Also...I know in the car settings you can change the brightness of the footwell lighting. Can this still be done with these new LEDs? Or do you need to use the remove to change brightness?
elamothe15 is offline   Reply With Quote
Old 07-18-2015, 02:01 AM   #9
deAutoLED.com
Drives: VW
These can be adjusted by the button on the controls but I do not think the MFD will adjust the brightness with these but I cannot recall. Keep us updated on that please.
Thank you
Old 07-24-2015, 09:04 PM   #10
deAutoLED.com
Drives: VW
No wiring is required, simply replace your current LED with ours and then choose from over 15 different colors including red, blue, green, orange, pink, purple, and many more!
These also have the ability to fade, flash with adjustable speed for each setting!
Old 08-03-2015, 07:22 AM   #11
deAutoLED.com
Drives: VW
With over 15 colors you can change your footwell color for every holiday.
Old 08-04-2015, 11:03 PM   #12
deAutoLED.com
Drives: VW
If you don't have these installed that means you don't know about them.
Our color changing footwells is one of our most popular sellers, have over 15 colors with a touch of a button, easy install - simply replaces your stock bulb with ours, simply plug & play and no modifications required!
Old 09-10-2015, 07:14 PM   #13
deAutoLED.com
Drives: VW
16 colors are better than 1!
Old 02-16-2016, 11:34 PM   #14
deAutoLED.com
Drives: VW
10% off Military discount!
Contact: http://deautokey.com/contact
Simply send them your info or email deAuto with a military email. It is that simple!
-They reply quickly – same day with your discount code
-Applies to anyone serving and vets also
-10% never expires - use it at anytime, no rush!
Thank you for your service!
Old 07-04-2016, 07:41 PM   #15
deAutoLED.com
Drives: VW
Anyone else celebrate independence day with 1 red & 1 blue footwell? Post up your photos!!
Old 07-29-2016, 02:27 PM   #16
deAutoLED.com
Drives: VW
LEDs are an investment.
Check out www.deAutoLED.com to see all our LEDs available!
LEDs:
-Are an upgrade to any car
-Creates a more appealing & modern look to your car
-Are safer and creates a more enjoyable riding experience
-Our LEDs come with a Lifetime Warranty!
This is one of the few mods that will normally add to your car’s resale value!
Old 07-29-2016, 02:47 PM   #17
Brinker
Drives: MK7
Says it doesn't ship to Canada, boo who!!!!��
Brinker is offline   Reply With Quote
