FORUM OPTIONS
Reply
Thread Tools Display Modes
Old 01-11-2017, 08:04 AM   #1
yellowc4s
Senior Member
Drives: MKVI GTI, 993 C4S
Speed Limiter
Do any of the tunes remove the speed limiter and if so, what is the top speed?
yellowc4s is offline   Reply With Quote
Old 01-11-2017, 11:48 AM   #2
Chronic
Senior Member
Chronic's Avatar
Drives: 2016 GOLF R DSG PURE WHITE
Quote:
I have the unitronic tune and it removes the speed limiter
Top speed,well haven't reached that yet but I've been over 160 mph
__________________
CTS Catless Downpipe,CTS Cold Air Intake,CTS TMD,CTS TIP,CTS TOP,CTS Throttle Pipe,CTS Crank Pulley,Audi Resonator Delete,Unitronic Stage 2 Ecu/Tcu,Centre Console Opened,Tinted Windows 5%Back 20%Front
034 Motorsport Dogbone,034 Motorsport Rear Sub Frame Mounts,034 Strut Mounts&Bearings,Emmanuele Design Springs,NGK RS7 Plugs,More Mods Coming.....
Chronic is offline   Reply With Quote
Old 01-11-2017, 03:07 PM   #3
jovian
Senior Member
Drives: 2016 GTI
Most dealer flash tunes remove the limiter and some handheld flashes do.
Piggybacks do not for obvious reasons.
jovian is offline   Reply With Quote
Old 01-11-2017, 08:38 PM   #4
edge04
Member
Drives: a lot
what is it limited to stock?
edge04 is offline   Reply With Quote
Old 01-11-2017, 09:07 PM   #5
Chronic
Senior Member
Chronic's Avatar
Quote:
250kph
__________________
Old 01-11-2017, 09:09 PM   #6
jovian
Senior Member
Drives: 2016 GTI
Old 01-11-2017, 09:14 PM   #7
Chronic
Senior Member
Chronic's Avatar
Quote:
My R use to tap out at 250km and like I said now I've been up and past the 160 mph
And the fastest I've been is 280km with lots of pedal left
Maybe the Canadian ones are governed differently
__________________
Old 01-11-2017, 09:24 PM   #8
GarabinS
Senior Member
Drives: Mk7 GTI
The US GTI is ~ 125 mph and the R is 155 mph
GarabinS is offline   Reply With Quote
Old 01-17-2017, 02:07 AM   #9
md2185
Member
md2185's Avatar
Drives: 16 MK7 Golf R dsg lapiz blue
Quote:
100% right
It would of had a better top end if they would add a 7th gear or made the 6th a longer ratio to pull higher and lower the rpms. Imo it already hovers high as it is at 80mph
md2185 is offline   Reply With Quote
Old 01-17-2017, 02:52 AM   #10
Fernflex
Senior Member
Drives: 2015 Gti S Lightning Pkg
Remember to change the tires!
__________________
Golf R Dsg 11.8@115mph
Mods: JB4+ Apr stg 1, Afe Drop in, 3" Catless Dp, Neuspeed Turbo to Intercooler Pipe, Cts Turbo Inlet hose and inlet pipe, Usp Throttle Pipe, Bms Meth kit, Wagner Intercooler.
383whp with less mods in February!!!
Fernflex is offline   Reply With Quote
Old 01-17-2017, 05:43 AM   #11
md2185
Member
md2185's Avatar
Quote:
We R folks dont have to worry, the contis are solid to the proclaim govern speed.
http://www.tirerack.com/tires/tirete....jsp?techid=35
For those that are no familiar with the ratings..
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
