Tsi7
- Ontario, Canada
Hey all, I have some very interesting symptoms i'd like to share.
Whenever I do a cold start and the rpms hover around 1500rpm, my car does this weird acceleration on it's on. So I get in my car in the mornings, start the car, let it idle for about 30s to a 1 min depending on how cold it is, then I drive off... normally the rpm is around 1400-1500 by the time I start moving. Then as I drive, in 2nd gear, or 3rd, or 4th, if I let off the gas, the car still accelerates on it's on...but it's not like it's giving gas, it just keeps pulling at a constant rate and the rpms continue to rise of course, when normally it should start to slow down, especially if it's in gear. Also, if I let the car pull forward at this constant acceleration, and I eventually press the clutch to stop the pulling, I hear this whistling/whirling/whooshing noise, kind of like a tdi when you switch gears that doesn't have a muffler, or a a turbo car that has a blowoff valve...
This only happens when the engine is cold, when it has warmed up and the rpm stabilizes to normal idle, it doesn't happen
Thoughts?
Thoughts?
