FORUM OPTIONS
Reply
Thread Tools Display Modes
Old 09-12-2017, 03:05 PM   #18
bdelaney4000
Senior Member
bdelaney4000's Avatar
Drives: 16' MK7 GTI S 6MT
Quote:
Originally Posted by Radfox View Post
How do you force readiness with a VCDS? What is the procedure?
Also what CEL code are you guys getting?
There's a video on youtube outlining the procedure just search for VCDS readiness. Most get the P0420 check engine light code for catalyst efficiency. Most aftermarket high flow cats aren't as efficient as the OEM cat causing the code. This can typically be defeated with a spacer to eliminate the CEL.
__________________
'16 MK7 GTI S 5DR 6MT
Unitronic Stg 2 | NGK RS7 Plugs | Eurocode Catted DP | Vibrant 17930 Res | GFB DV+ | BFI Stg 1 Eng/Trans | 034 Dogbone | Leyo Turbo Inlet | ECS Turbo Muffler Delete | Spulen Outlet Pipe | ECS Short Shifter w/ Bushings | IE Cable Bracket w/ Bushings | ECS BleederBlock | K&N Panel Filter | BMS Clutch Stop | OBDEleven
bdelaney4000 is offline   Reply With Quote
Old 09-12-2017, 03:11 PM   #19
-Dutch-
Senior Member
-Dutch-'s Avatar
Drives: 2017 Golf GTI SE
http://www.ross-tech.com/vcds/tour/readiness.php
__________________
I have no idea what I'm talking about.
-Dutch- is online now   Reply With Quote
Old 09-13-2017, 12:01 PM   #20
rcode
Senior Member
rcode's Avatar
Drives: 2016 R
Quote:
Originally Posted by russiankid View Post
With a JB4, CTS catted DP and 42DD spacer facing the ABS module, there are no CEL's and passes all readiness monitors. The CTS catted DP has the O2 bung before the cat so the 42DD does a good job at keeping the CEL away.
Thanks. I was either going to try the vibrant or 42dd spacer but maybe I'll just buy both and see which works best.
rcode is offline   Reply With Quote
Old 09-15-2017, 03:22 PM   #21
Triton
Member
Triton's Avatar
Drives: 2016 Golf R
There is no such thing as forcing readyness. You can force the ecu to run the test but that doesn't guarantee you'll pass. I have used the procedure above on my mk6 gti but when I had to smog my mk7 R that procedure doesnt work.
__________________
16' LB R | DSG | APR Stage II HT |
11' SB GTI
| DSG |APR v3.1|CTS K04 |
06' BM GTI | 6sp | Tuned |
Triton is offline   Reply With Quote
Old 09-15-2017, 03:50 PM   #22
bdelaney4000
Senior Member
"Forcing Readiness" is just the term commonly used to describe the procedure to "force" the ECU to run the tests without going having through a full drive cycle. Not every state run smog like CA. Looks like the OP is from Long Island.
__________________
Old 09-15-2017, 03:53 PM   #23
Gawernator
Senior Member
Gawernator's Avatar
Drives: '17 Wolfsburg 1.8T; '15 ZX6R Racebike (x2)
FWIW I fixed my CEL last night. I got a $17 O2 spacer off Amazon and figured out the right config since its modular. You just have to play around with it until it works right
__________________
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | Bridgestone | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Gawernator is online now   Reply With Quote
Old 09-15-2017, 04:36 PM   #24
bdelaney4000
Senior Member
Quote:
Congrats! Yeah sometimes with those modular/adjustable ones you have to fiddle around with them to get them set just right. Glad it worked out for you though.
__________________
Old 09-15-2017, 04:40 PM   #25
Gawernator
Senior Member
Gawernator's Avatar
Thanks. I just unscrewed the lower section so reduce the overall size. It was throwing a lean code so it was too far out of the stream I guessed. Two days so far no code.
__________________
Old Yesterday, 11:50 PM   #26
rcode
Senior Member
rcode's Avatar
Drives: 2016 R
Flashed to GIAC stage 2 today and the CEL that comes back every once in a while is gone. I left it on before the flash to see what would happen. Haven't had a chance to check readiness yet but I assume I'm still failing. Will try to get the 02 spacer in over the weekend and report back.
Old Today, 02:53 AM   #27
rcode
Senior Member
rcode's Avatar
Drives: 2016 R
Quote:
Yes, correct no smog here. Just a description of the process instead of running the drive cycle.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
