magellanqa
- turkey
Hello to everyone
I know that this issue has been opened many times but my question is different. My car is 2014 golf 7 gti and l install to my car cracked Discover pro mib 2. The Mib2 is fully functional, including sports gauges(boost,g sensor and kw) in my car. But the sports gauges and the off-road gauges do not get information about oil and water temperature. How can I get information for oil and water temp?
Code:
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F A9
VIN: WVWZZZAUZEW347733 Mileage: 43780km-27203miles
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
Address 01: Engine (J623-CHHB) Labels: 06K-907-425-V1.clb
Part No SW: 5G0 906 259 C HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 091D00324444050B3000
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_ECM20TFS0205G0906259C 001005
ROD: EV_ECM20TFS0205G0906259C_VW37.rod
VCID: 2E4A1EE32017BCF2BDAC28D-807A
1 Fault Found:
21471 - Databus
U1122 00 [039] - Implausible Message
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 43780 km
Date: 2017.08.16
Time: 01:03:26
Readiness: 1110 0001
Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb
Part No SW: 0D9 300 041 C HW: 02E 927 770 AQ
Component: DQ250-6F MQB H52 4902
Revision: 05852204 Serial number: TFK01406181768
Coding: 0014
Shop #: WSC 04742 780 00200
ASAM Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021_AU37.rod
VCID: 1826D83BB2935242C790DE5-804C
No fault code found.
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 L HW: 5Q0 907 379 G
Component: ESC H31 0471
Revision: 00000000 Serial number: 6062400000072E
Coding: 01FA6BA134242973037E0603C1C6A980D62C94C0608395F718425038C206
ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
ROD: EV_Brake1UDSContiMK100IPB_VW37.rod
VCID: 4598414F95A11FAA6CD62F9-8010
2 Faults Found:
8299 - Databus
U1121 00 [009] - Missing Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 22
Date: 2017.08.16
Time: 01:03:28
8309 - Engine Control Module Incorrectly Coded
P1612 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 22
Mileage: 43780 km
Date: 2017.08.16
Time: 01:03:31
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Part No SW: 5Q0 959 435 A HW: 5Q0 959 435
Component: VWKESSYMQB 021 0604
Revision: 00021000 Serial number: 0329392134
Coding: 030C0C
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_KessyHellaMQBAB 002011
ROD: EV_KessyHellaMQBAB_AU37.rod
VCID: 3A6222B3EC5F6052112454D-806E
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5G0 907 044 T HW: 5G0 907 044 T
Component: Climatronic H02 0912
Revision: 00001K06
Coding: 00020014200100011005005000101022
ASAM Dataset: EV_ACClimaBHBVW37X 003018
ROD: EV_ACClimaBHBVW37X_SK37.rod
VCID: 386638BBD2537242E750BE5-806C
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AE
Component: BCM MQBAB H H16 0137
Serial number: 00011406601207
Coding: 00111A42C24122FB4BE44000000C07A81800000000000000000000000000
ASAM Dataset: EV_BCMCONTI 013000
ROD: EV_BCMBOSCH_AU37.rod
VCID: 0016905BCA03FA821F60D65-8054
Slave 1:
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 140304 042 0551
Serial number: 140307003752
Coding: 0E4DDD
Slave 2:
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y14M03D15H06M00S26S7
Coding: 06A8DD
Subsystem 3 - Part No SW: 8V3 959 591 HW: 8V3 959 591
Component: J245 PS73.013 H02 0007
Serial number: WOO27687048
Coding: 181901
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 F HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0142
Revision: -------- Serial number: 39331407601372
Coding: 0031151011
ASAM Dataset: EV_EPHVA18AU3700000 002024
ROD: EV_EPHVA18AU3700000_SK48.rod
VCID: 3E6A2EA3F0774C722D0C78D-806A
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-567.clb
Part No SW: 5Q0 907 567 G HW: 5Q0 907 567 G
Component: ACC3 H07 0386
Serial number: 18041276110205
Coding: 00001100FE0309
Shop #: WSC 00028 028 00312
ASAM Dataset: EV_ACCBoschMQB 001020
ROD: EV_ACCBoschMQB_VW37.rod
VCID: 3F9453A7F77D457A261A6D1-806A
Address 15: Airbags (J234) Labels: 5Q0-959-655.clb
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 014 0386
Serial number: 003MLR048JBT
Coding: 98CCC000000000005C0000CF004800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002130
ROD: EV_AirbaVW20SMEVW37X_AU37.rod
VCID: 7F1413A7B7FD857A669AAD1-802A
Seat belt tensioner; left:
Subsystem 1 - Part No SW: 5G0 980 945 B HW: 5G0 980 945 B
Component: BeltPretRevFL H35 0341
Serial number: 34169667B11031441090
Coding: 333135
Seat belt tensioner; right:
Subsystem 2 - Part No SW: 5G0 980 946 B HW: 5G0 980 946 B
Component: BeltPretRevFR H35 0341
Serial number: 34169668B12031440569
Coding: 333135
Crash sensor for side airbag; driver side:
Subsystem 3 - Part No SW: ----------- HW: 480 002 102 14
Component: SideSensor_Df 001 0887
Serial number: 35767000000F56A41F0+
Coding: 2D2D2D
Crash sensor for side airbag; front passenger side:
Subsystem 4 - Part No SW: ----------- HW: 480 001 003 14
Component: SideSensor_Pf 001 0887
Serial number: 35867000000C62E42F0+
Coding: 2D2D2D
Crash sensor for side airbag; rear; driver side:
Subsystem 5 - Part No SW: ----------- HW: 480 400 503 14
Component: SideSensor_Dr 001 6149
Serial number: 3516502BB12F6292537A
Coding: 2D2D2D
Crash sensor for side airbag; rear; passenger side:
Subsystem 6 - Part No SW: ----------- HW: 480 400 303 14
Component: SideSensor_Pr 001 6149
Serial number: 3526502B912FAE23E2EY
Coding: 2D2D2D
Crash sensor for front airbag; driver side:
Subsystem 7 - Part No SW: ----------- HW: 480 400 503 14
Component: FrontSensor_D 001 6149
Serial number: 3556502BF142B1C4B13G
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 EA HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 04031408490744
Coding: 0410
Shop #: WSC 00070 000 00000
ASAM Dataset: EV_SMLSKLOMQB 017001
ROD: EV_SMLSKLOMQB_SE37.rod
VCID: 79E0FDBFA9D9AB4A58DEE39-802C
Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb
Part No SW: 5G6 920 870 HW: 5G6 920 870
Component: KOMBI 314 2210
Coding: 07AD09182F80000800087A00040000
ASAM Dataset: EV_DashBoardVDDMQBAB 008031
ROD: EV_DashBoardVDDMQBAB_AU37.rod
VCID: 6CCED4EBD68B0EE2D358725-8038
Address 19: CAN Gateway (J533) Labels: 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 M
Component: GW MQB High 212 2246
Revision: -------- Serial number: 23111510001899
Coding: 030100042B085900FF00026E1C0F00010001000000000000000000000000
Shop #: WSC 80002 389 00000
ASAM Dataset: EV_GatewConti 013020
ROD: EV_GatewConti.rod
Alternator:
Multifunction unit control module:
Subsystem 2 - Part No SW: 5G0 959 442 S HW: 5G0 959 442 S
Component: E221__MFL-DC1 H10 0040
Serial number: 29150001362370085282
Coding: 35FFFF
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 5672212803
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Part No SW: 5Q0 905 861 A HW: 5Q0 905 861 A
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 14000047037004
Coding: DD00000000000000
ASAM Dataset: EV_ELVMarquMQB 004111
ROD: EV_ELVMarquMQB_AU37.rod
VCID: 347E0C8BCE3B9622CB68EA5-8060
Address 42: Door Elect, Driver (J386) Labels: 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 07031401101486
Coding: 001F1320D000048000001000
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
VCID: 4096505B8A833A825FE0165-8014
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A
Component: FOND_FHSG_DRV 005 0005
Serial number: 00000000000002055791
Coding: 010000
Address 44: Steering Assist (J500) Labels: 5Q0-909-144.clb
Part No SW: 3Q0 909 144 F HW: 3Q0 909 144 F
Component: EPS_MQB_ZFLS 503 5043
Coding: 8103
Shop #: WSC 12166 003 1048576
ASAM Dataset: EV_SteerAssisMQB 010031
ROD: EV_SteerAssisMQB.rod
VCID: 3578318FC5418F2AFC769F9-8060
Address 52: Door Elect, Pass. (J387) Labels: 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 10031401100145
Coding: 001F1120DE00048000801000
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A
Component: FOND_FHSG_PSG 005 0005
Serial number: 00000000000002080220
Coding: 190000
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Revision: -------- Serial number: --------------
Coding: 029A01000B000200
ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
ROD: EV_HeadlRegulVWAFS_SE26.rod
Subsystem 1 - Part No SW: 3D0 941 329 HW: 3D0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H05 0012
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 HW: 3D0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H05 0012
Coding: 2E0000
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 3G0 035 046 C HW: 3G0 035 046
Component: MU-H-TN-RW H40 0814
Serial number: A600L0EB000412
Coding: 0273000AFF01000011110001000908101F0103D401200100FE
ASAM Dataset: EV_MUHig4CGen2HBAS 001001
ROD: EV_MUHig4CGen2HBAS_BY63.rod
VCID: 1F54F32757BD257A065A8D1-804A
Media Player Position 1:
Radio Tuner - Digital:
Subsystem 2 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H62 0031
Serial number: VWZ8Z9PU300VG4
Engine Control Module 2:
Subsystem 3 - Part No SW: ----------- HW: -----------
Component: ------------- --- ----
Serial number: --------------------
Seat Adjustment Driver Side:
Subsystem 4 - Part No SW: V03 959 801 DT HW: -----------
Component: ROW 2015 --- 0039
Air Conditioning Compressor:
Diesel Pump Control Unit:
Door Electronics Driver Side:
Subsystem 7 - Part No SW: ----------- HW: -----------
Brake Assistance:
Subsystem 8 - Part No SW: ----------- HW: -----------
Interior Monitoring:
Subsystem 9 - Part No SW: ----------- HW: -----------
Sound System:
Door Electronics Rear Left:
Subsystem 12 - Part No SW: ----------- HW: -----------
Subsystem 13 - Part No SW: ----------- HW: -----------
Subsystem 14 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2--- --- 4005
3 Faults Found:
2571 - Navigation system
B126C F2 [009] - Navigation database not enabled
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 22
Mileage: 43780 km
Date: 2017.08.16
Time: 01:03:31
3073 - Cellular Antenna
B1053 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 22
Mileage: 43780 km
Date: 2017.08.16
Time: 01:03:31
2565 - GPS Antenna
B1054 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 22
Mileage: 43780 km
Date: 2017.08.16
Time: 01:03:31
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0013
Serial number: 140214202308
ASAM Dataset: EV_SoundActuaGen2AU64X 003010
ROD: EV_SoundActuaGen2AU64X.rod
VCID: 6BCCD7F7D38509DADA52491-803E
