Hi guys. Anyone know what oil the 2016 GTD uses in the UK? The book just says VW long life...
Specification must be 507.00
Thanks, do you know why? Or what happens if it's not?
Same as it does anywhere else. VW 507 00 (Longlife III).Hi guys. Anyone know what oil the 2016 GTD uses in the UK? The book just says VW long life...
It doesn't need to be 5W-30. What's 'll' for 'Longlife'? OrCheers you're right it's 5w30ll
These are either 0W-30 or 5W-30. Same applies to any
current DPF equipped VW Diesel car. It does not matter
whether you're running fixed or flexible intervals (on the
Diesels).
Volkswagen used to use a Castrol 5W-30 while currently
filling Shell Helix Ultra AV-L 0W-30 from factory. On a side
note, Shell Helix Ultra ECT 0W-30 is the exact same stuff
as Helix Ultra AV-L 0W-30, as is Volkswagen's own Vapsoil
507 00 Premium 0W-30. Just the bottles differ.
VW recommend Castrol Oils on their website and the cars are 'borne at th
"Longlife II"?
Don't use "Longlife II" which equals to VW 506 01 (and is
0W-30 only) and was designed for early Pumpe-Düse TDIs
without DPF.
Lastly, RTFM !!
WOW.I buy genuine Quantum 5w30 oil from ebay, £19.00 for 5 liters and most sellers are main dealers.
Sent from my SM-G930F using Tapatalk
Can you provide the eBay link for this article - thanksI buy genuine Quantum 5w30 oil from ebay, £19.00 for 5 liters and most sellers are main dealers.
Just type Quantum oil in ebay search bar, quite few sellersCan you provide the eBay link for this article - thanks
