Ohlns R+T
Ohlins R+T!
My big suspension project was just completed and I wanted to share some impressions for anyone interested or contemplating doing some work on their Mk 7 GTI.
The installation, corner balancing, alignment, and settings was done by Joey Seely at Emotion Engineering (
http://emotionengineering.co/about/) in Costa Mesa, CA. His main business is making street Porsches handle even better, and he also does suspension race prep for a number of customer IMSA and ALMS team. I was referred by a good friend who is the Cal rep for Falken Tire because among Joey’s cars is a Golf TDI that’s his DD. He’s the Suspension Whisperer.
Before meeting Joey I had ordered Ohlins R+T coilovers. He said he has a slight preference for KW, but mine were already en route. At his suggestion I also procured Ground Control adjustable top mounts for the front, and adjustable sway bar end links by White Line at both ends. All of this stuff is so beautiful and of such high quality. It must be how women feel about jewelry.
The settings he used are 2.4 degrees of front camber, 2.0 degrees rear camber, and 1.5 degrees of rear toe. I’m sure I will wear out tires at an accelerated rate and will have to rotate them frequently.
The difference is a profound improvement in handling. Even at low speeds and just driving around town, the GTI feels more like a race car. When pushing on, turn in is instant and very sharp. There is zero understeer. I mean absolutely zero. The rear is also very stable. It’s all so linear feeling. The car feels like someone cut 500 pounds off the curb weight. The handling is very, very lively. Steering feel (which is to me the thing really lacking in the stock trim, along with the numb, shitty clutch) is high and precise. I can push so much harder now because all of this adds up to a package that inspires so much confidence. Also, the car doesn’t feel twitchy or nervous at high speeds in a straight line.
I expected the ride to be compromised, along with an increase in road noise. I was warned away from the front shock mounts on the grounds that they would introduce unwanted NVH. The pleasant and unexpected consequence of everything is that my car actually rides better than before (I was on VWR springs and stock shocks). It’s all quieter and tidier when just going about the day to day business of getting around. This is like the Holy Grail!
The one minus is that hitting sharp bumps at highway speeds definitely results in a more dramatic thud. You feel it, and it’s pretty loud. I'm not sure about the front bump stops or what can be done about this.
So all in all I’m absolutely delighted with the end result. It was a really expensive project, but the results are an epic improvement in driving joy. I wish I’d done it all when the car was brand new and not wasted the time and money on just slapping springs onto the car.
