FORUM OPTIONS
Reply
Thread Tools Display Modes
Old 10-10-2017, 01:16 AM   #205
Diggs24
Senior Member
Diggs24's Avatar
Drives: 2015 GTI; 2003 Saab 9-3 SS
https://datazap.me/u/kettamean/
Only 1 log there.
__________________
JB4 / IE Intercooler / MAP cat+res Downpipe
Diggs24 is online now   Reply With Quote
Old 10-10-2017, 04:04 AM   #206
Kettamean
Member
Drives: 2017 Golf R
Not sure what is going on with the links. If this one doesn't work, I'll definitely be scratching my head:
https://datazap.me/u/kettamean/4th-l...19-25-26-27-28
Kettamean is offline   Reply With Quote
Old 10-10-2017, 05:24 AM   #207
Diggs24
Senior Member
Diggs24's Avatar
Looks fine to me.
__________________
Old 10-11-2017, 04:21 PM   #208
blahblah
Junior Member
Drives: 2016 Golf R
How is the JB4 at very high altitude?
I had a JB1 on my R for a year an loved it, I miss it. I sold the JB1 when I moved to Mexico City from Socal and tried to sell my 2016 R, I have decided to bring my R to Mexico City. The main drive I do, 1-3 times a week, is from Mexico City to Tepoztlan. From 7500 ft up to over 10,000 ft then down to 6,000. I drive the car quite hard and don't want to worry about blowing the turbo. Will a JB4 help produce any more power or torque than stock at these altitudes? Will a downpipe help? Can the JB4 work with a larger turbo?
blahblah is offline   Reply With Quote
Old 10-17-2017, 11:10 AM   #209
George Smooth
Senior Member
George Smooth's Avatar
Drives: Golf 7 R
It is fine. we developed the unit at 5600ft. If you going to use map 6 we just need to keep a eye at peak boost from 6000 and up.
At your altitude torque will be similar to coast and maybe around 10whp down at high rpm vs the coast.
On the R the JB4 cannot provide sufficient fueling for a big turbo.
George Smooth is offline   Reply With Quote
Old 10-17-2017, 02:14 PM   #210
George Smooth
Senior Member
Drives: Golf 7 R
Some nice results by Bradley on this full weight DSG R running a E25 mix with a full weight car on all seasons. Tires pressures where dropped which affected the exits drastically.
Mods:
BMS JB4
BMS Meth kit
IE Carbon Intake
Leyo Motorsport Boost Pipe Kit
Leyo Motorsport Turbo Muffler Delete
Leyo Motorsport Turbo Inlet
Forge Intercooler
Forge Turbo Blanklet
Milltek Catless Turboback - Non Resonated/Non Valved
Slip:
Log:
Old 10-19-2017, 07:34 PM   #211
blahblah
Junior Member
Drives: 2016 Golf R
Okay.. I ordered a JB4.
Is a downpipe a good way to reduce the turbo lag at high elevation? Will a larger intercooler increase lag noticeably at high elevation? Can I run Map 2 with a downpipe at 10,000 ft with 93 fuel? Anyway I will log...
Old 10-19-2017, 09:06 PM   #212
Schnell_R
Senior Member
Drives: 2017 Golf R DSG
A larger charge air cooler will not hamper spool up.
Schnell_R is offline   Reply With Quote
Old 10-19-2017, 09:10 PM   #213
Schnell_R
Senior Member
Change one thing at a time. Don't go fixing problems before they are known. I would run the jb4 solidly for a month before making changes. A better flowing downpipe is always welcome in a performance application.
Old 10-21-2017, 03:44 PM   #214
Daument
Member
Drives: 2017 R
I've recently upgraded my JB1 to JB4. I now have part and full throttle surging on map 2, Map 6 surges at part throttle but seems smooth at full throttle.
MAP2 first pull
2017 Golf R 6MT
no mods
60 degree day
3rd gear
1stpullmap2 by daument100, on Flickr[/IMG]
MAP2 second pull
same as above
2ndpullmap2 by daument100, on Flickr
MAP6
IMG_0452 by daument100, on Flickr
MAP6 Settings
map6 settings by daument100, on Flickr
Any ideas?
thanks !!
Daument is offline   Reply With Quote
Old 10-21-2017, 03:55 PM   #215
Diggs24
Senior Member
Diggs24's Avatar
Ask George for newest firmware.
__________________
Old 10-23-2017, 04:36 PM   #216
OliS3
Junior Member
Drives: Audi S3
I was wondering how launch control works for you running a JB4
I run map 6 with 1st gear boost limited to 18.5psi and it was working fine. Now it takes off hard and about 5k rpm I get a massive loss of power and it takes a second until the power kicks in and then the car runs fine.
I assume it is a torque limiter or traction control coming in (I do have ESC fully off)
If I do a few in a row by the 3rd it works fine and continues to work fine (extra tyre temp or the car pulling power from getting warm?)
OliS3 is offline   Reply With Quote
Old 10-23-2017, 04:39 PM   #217
Diggs24
Senior Member
Diggs24's Avatar
Can you log this?
__________________
Old 10-23-2017, 04:48 PM   #218
OliS3
Junior Member
Drives: Audi S3
Quote:
Originally Posted by Diggs24 View Post
Can you log this?
I can't see why not, I think it is down to the extra torque the JB4 adds as others have had issues with the JB1 and dropping down the boost from 5 to 4.8 has solved it.
I was just wondering how many others have these issues
Old 10-28-2017, 09:22 PM   #219
lebenfitti
Junior Member
Where are we at on the firmware upgrade?
Sent from my SM-T230NU using Tapatalk
lebenfitti is offline   Reply With Quote
Old 10-28-2017, 09:30 PM   #220
Daument
Member
Drives: 2017 R
George looked at the logs and sent new firmware. Itís been a few hundred miles since the update was installed. It still has a slight surge around 3500 with part throttle but itís virtually unnoticeable if your not driving it. Iíll be installing an AWE down pipe in the next few weeks, weíll see how that works out.
Old 10-31-2017, 07:20 PM   #221
Mak_Attack
Member
Drives: 2017 Golf R
If i buy the bluetooth kit do i still need the data cable?
Mak_Attack is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
