FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Technical Topics > Exterior / Interior Care (washing, detailing, exterior repairs)
Reply
Thread Tools Display Modes
Old 09-02-2016, 07:54 PM   #18
The Fed
Senior Member
The Fed's Avatar
Drives: 2016 Golf R
Keep in mind that OEM glass has the VW logo on it. If you trade the car in the appraiser will note this and offer you less.
__________________
(Mostly) Posted by Josh/AWE. Flapper valves are open at idle, close after 1100 RPM during part throttle. Full throttle 1st-4th gear the valves open until throttle let off. 4th gear, 1500 RPM to full throttle closed, closed until 3500 RPM, then open until lift off throttle.
The Fed is offline   Reply With Quote
Old 09-06-2016, 02:51 AM   #19
wordsthatiwrote
Senior Member
wordsthatiwrote's Avatar
Drives: 2016 VW Golf GTI SE
Quote:
Noted. Thx.
__________________
AEM short throw intake - Boomba Racing Diverter Valve Spacer with holes in it
wordsthatiwrote is offline   Reply With Quote
Old 01-05-2017, 03:18 AM   #20
picollo
Member
Drives: mk7 tsi
Quote:
Originally Posted by sprinks View Post
What?! Safelite did mine for under 400. There's definitely non-oem glass now. Had mine replaced in march-ish with the Fuyao glass.
Were you pleased with them? I have got to change mine this month to pass the state inspection. Thank you in advance for your response.
picollo is offline   Reply With Quote
Old 01-05-2017, 08:50 PM   #21
sprinks
Senior Member
Drives: GTI Mk7
It's worked fine for me. No leaks, ~1.5 hours in the shop and a guarantee if a problem arose. I'm approaching a year later with no issues thus far. If i get another crack in it in a few years i'll replace it with safelite once again.
__________________
wheelwell
sprinks is offline   Reply With Quote
Old 01-07-2017, 03:17 AM   #22
picollo
Member
Drives: mk7 tsi
Thanks. I am getting quotes now...I may just have it done by them.
Old 01-09-2017, 01:33 AM   #23
2slowvw
Moderator
2slowvw's Avatar
Drives: 2016 GTI S
Got mine installed with aftermarket glass about 8 months ago for less than 300, no issues so far.
__________________
Cheap, fast, or reliable. Pick two.
2slowvw is offline   Reply With Quote
Old 01-09-2017, 01:57 AM   #24
picollo
Member
Drives: mk7 tsi
Quote:
I've got a couple of quotes, including Safelite...they're all above $350. This is in Charlottsville area. The original quote I got from Safelite was over $400...They lowered it to $365...I will try to get them to lower it some more...We shall see.
Old Yesterday, 01:51 AM   #25
picollo
Member
Drives: mk7 tsi
I ended up getting it changed by Glas Doctor in Charlottsville. Total came out to $304.
They were very easy to work with, very responsive and upfront about alll the fees, etc., unlike Safelite. Total out of pocket with Safelite, after discount, would've been almost $450. Thanks all.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
