Norsk982
- MALVERN, PA
Any recommend on how to get the Clamps off the rear sway bar???
Looking for some info!
Does anyone know a location to purchase aftermarket front sway bar bushings for the front OE bar? 24mm bar for GTI.
One can find them but only sold in package with a new sway bar.
Even OE bushing only sold as a set.
Yes thicker front bar and option but to install front suspension must be lowered which require alignment after. No against, just would rather not do this now.
Any help appreciated.
Update from me to me!
The OE bar has the bushing molded to it. Per ECS Tuning. Bar must be replaced to replace bushing. Great design VW.
So, looks like upgrade and dealer install because few will do VW alignment it seems.
Firestone dealer recommended I use VW for alignment so likely limited options.
I guess if I have front done might as well do rear. Which I can do myself depending on dealer price for the set installed.
So another coordinated plan to deliver car in Chattanooga (3 hour round trip) and get install work performed.
Lovely
VW actually did this for a reason.
Some will remember Mk4s used to suffer from front end knocking due to
worn swaybar bushings, since there's friction in conventional swaybar
bushings causing wear.
For that reason VW developed 'non-frictional bushings' that are glued to
the swaybar, first introduced on the Mk5. The SSP pic doesn't show the
'voided' intersection between inner and outer half of the bushing. Hope
you can see it on the photo.
That said, I remember SuperPro, Whiteline and others did offer stiffer
replacement bushings for use along with the stock swaybar. Did you
check their websites?
