FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Volkswagen GTI / Golf MK7 General Topics > Golf R Discussions
Reply
Thread Tools Display Modes
Old 04-20-2017, 07:44 PM   #18
Senior Member
Sandman GTI's Avatar
Drives: GTI MK7 Autobahn, PP, DCC+LP, 97 F-150 4.6L V8
Quote:
Originally Posted by ImolaR View Post
Sounds like the Iron-X would be great to use on the wheels..I never heard of the stuff before now.
Yes on wheels.
Just never let it dry.
I was car first.
Then Iron-X a panel at a time. Let sit 5 min. Wipe down with MF to make sure it gets everywhere. Hose off. Wash car again quickly. Clay and wax as you like.
Every 6 months is good unless you want more.
__________________
Sandman
My Build Thread: http://www.golfmk7.com/forums/showthread.php?t=6100
Sandman GTI is offline   Reply With Quote
Old 04-21-2017, 12:41 AM   #19
EmptyHeaded
Member
Drives: 2017 MK7 .:R & 2003 EJ205 Wagon
Quote:
Originally Posted by alexspeed3 View Post
Learning a lot from this discussion. Is what you refer as sealant same as wax?
Think of sealants as modern day waxes. They're made up of polymers that are designed to bond to the surface of your paint to provide a durable protection against the elements. While they don't provide the same depth and gloss as your traditional carnuba waxes, they definitely provide additional protection and durability between treatments, meaning you don't have to re-apply as frequently. To take it a step further, many people like to use a sealant after they wash and then top the sealant with a wax, just to help bring out that additional depth and gloss that they might not get with a sealant alone.
To properly do a detail I am understanding the following:
Rinse
Ironx
Rinse
Clay
Sealant then wax?
These are good steps for a full detail, however once you've established a solid foundation for protection, you can simply wash and dry your car as you would normally to keep it looking nice and clean. Generally I'll detail my car 2x a year, but only Iron X/clay it 1x. Washes usually consist of me washing with 2 bucket method, with the rinse bucket being a mix of clean water and Optimum No Rinse mixed in, and then towel dry with a hydrophobic quick detailer spray/sealant (I like Chemical Guys V07), and be done with it. With a bit of work on the front end, it really makes it easy to maintain and keep looking great with minimal effort over time!
EmptyHeaded is offline   Reply With Quote
Old 04-21-2017, 01:17 AM   #20
Gogo GTI
Senior Member
Gogo GTI's Avatar
Drives: 2017 GTI Sport DSG
Any opinions about nanoskin? I've read enough to convince me to buy it but haven't had the chance to use it yet. Just thought I'd get additional opinions if I could before giving it a try.
Gogo GTI is offline   Reply With Quote
Old 04-21-2017, 11:43 AM   #21
AdrenalineChick
Senior Member
AdrenalineChick's Avatar
Drives: 2017 Golf Alltrack SEL
This is a life changer:
https://www.amazon.com/Speedy-Surfac...rds=clay+towel
It's a clay bar in towel form. Cuts claying time in half or more. If you drop it, just rinse it off.
Not sure what you guys are using for clay, but for anyone that doesn't know about this, get one! I used it on my white MK6 GTI and it got brake dust off the paint with almost no effort. Just make sure you use a sealant after (I use Sonax Polymer Net Shield, which also changed my life).
__________________
~Kimberly~
2017 Golf Alltrack SEL | DAP/Lighting | Platinum Gray Metallic
AdrenalineChick is offline   Reply With Quote
Old 04-21-2017, 12:41 PM   #22
17lc9x
Junior Member
Modern vehicles are all basecoat clear coat. Usually a waterborne basecoat with a solvent borne clear coat. Only one manufacturer makes a water borne clear coat but it hasn't caught on (slow dry times). Older cars and large vehicles (think buses and trucks) used or still use single stage acrylic enamels or acrylic urethanes. Base/clear is much more durable and you won't see paint transferring to your clay bar or compound pad.
17lc9x is offline   Reply With Quote
Old 04-21-2017, 12:41 PM   #23
Porknozzle
Junior Member
Porknozzle's Avatar
Drives: 2017 R
Quote:
A word of caution here. Contaminants removed using a traditional clay bar are embedded into the clay away from the surface. Non-clay-bar substitutes do not and you can do more harm than good because the contaminants are trapped between the paint and whatever else you're using.
I know Nanoskin is popular and one of the first products of its kind but now everyone is jumping on this bandwagon and some are so bad you'll end up with this mess like I got on my Challenger with Clayzilla from Surf City Garage. And yes, I used it according to instructions, wrote the manufacturer, got a refund after two replacements failed.
What you see here isn't the results of trapped contaminants, the Clayzilla pad is actually abrasive, another surprise awaiting those looking for a better mousetrap.
Porknozzle is offline   Reply With Quote
Old 04-21-2017, 04:57 PM   #24
sixspeedz
Member
sixspeedz's Avatar
Drives: 2016 Golf R
Nice job OP... I bought the same kit last weekend and plan on hitting the car next week followed by an application of Hydro2... Just waiting on my new pressure washer to come in
Nice to see it came out so clean with no polishing needed!
__________________
2016 LSG Golf R - APR Stage 1 (V2.3 93 Octane HIGH TQ) | SB Stage 2 Daily clutch | APR short shift kit | BFI Stage 1 Engine/Trans Mounts | 034 Dogbone Insert | S3 Resonator Delete | CTS Turbo Inlet Pipe | K&N filter
sixspeedz is offline   Reply With Quote
Old 04-21-2017, 05:03 PM   #25
ImolaR
Senior Member
ImolaR's Avatar
Drives: '16 Golf R (6MT) & BMW R nineT (motorcycle)
Thanks. What washer did you pick up? I use a small Karcher thats made for cars.
__________________
Check out my Instagram @V5Garage
ImolaR is offline   Reply With Quote
Old 04-21-2017, 06:21 PM   #26
sixspeedz
Member
sixspeedz's Avatar
Drives: 2016 Golf R
I have a SunJoe SPX3000 on it's way and some Chemical Guys honeydew snow foam. I think I'll get some Iron-x before I do the work though.
We have 3 cars to maintain, so all this stuff pays for itself after only one summer of avoiding the commercial car washes.
__________________
Old 04-21-2017, 06:40 PM   #27
Diggs24
Senior Member
Diggs24's Avatar
Drives: 2015 GTI; 2003 Saab 9-3 SS
I use it and it's great. Just don't push really hard with it or the "clay" will come off the pad. Use plenty of lube. I use a diluted batch of Optimum No Rinse.
Be sure to break it in on a glass window first per the directions.
Diggs24 is offline   Reply With Quote
Old 05-02-2017, 12:00 AM   #28
sixspeedz
Member
sixspeedz's Avatar
Drives: 2016 Golf R
Followed suit
Decontamination and sealing today... Iron-x, Mother's clay bar, Hydro2 (amazing stuff), and Ultima Tire & Trim for the exterior, CarPro Perl on all things interior. Pics not nearly as good as yours, and the damn pollen was falling faster then I could work!
__________________
Old 05-02-2017, 01:27 AM   #29
ImolaR
Senior Member
ImolaR's Avatar
Nice! Car looking great. How is that interior cleaner? Does it leave a shine or odor?
__________________
Old 05-02-2017, 01:56 AM   #30
sixspeedz
Member
sixspeedz's Avatar
Drives: 2016 Golf R
This is my first Perl purchase. Used it on both my cars a few times only so far, but I really like it. You can dilute it in different ways to use it for exterior, interior, engine bay, rubber, leather, vinyl, etc. the most diverse stuff I've ever had. The more diluted, the less shiny.
Smells very neutral and doesn't linger long, but the product protects for a while and is very easy to go on.
I love my Ultima, which has lasted forever, but it stinks and is very oily and runny. I saw a great comparison of the 2 and the Perl can give the same or more protection and good looks as the Ultima can on the exterior parts if you apply 2-3 coats.
__________________
Old 05-09-2017, 06:52 AM   #31
MK_7R
Junior Member
Drives: MK7R
Picked up a couple of these and I think they are great! In fact, I have the clay mitts and the pads that hook up to my polisher.
As with all claying, use tons of lube. Personally, I foam the car up and use the foam as the lubricant. If the car has a lot of contaminants then I foam the car with Iron X snow foam and use that as the lubricant for the clay mitts - works wonders.
MK_7R is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
