FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Regional Forums > UNITED KINGDOM
Reply
Thread Tools Display Modes
Old 04-18-2017, 10:29 AM   #1
t-800
Member
Drives: RS3
Fitted new Discs and pads all round
Thought I'd put new discs and pads on our GTD this weekend.....
t-800 is offline   Reply With Quote
Old 04-18-2017, 01:58 PM   #2
jabba
Junior Member
Drives: VW Golf
Hi, did you have any problems removing the rear caliper carrier bolts ? I only ask as I'm going to replace mine soon. Many thanks
jabba is offline   Reply With Quote
Old 04-18-2017, 05:09 PM   #3
t-800
Member
Drives: RS3
Quote:
Not really..... you just need the car up as high as possible to get the long breaker bar in.
New spine bolts are required too.
Old 04-18-2017, 08:03 PM   #4
t-800
Member
Drives: RS3
Plenty of room for breaker and for Torque Wrench
Old 04-19-2017, 07:22 AM   #5
Mikeyd1
Senior Member
Mikeyd1's Avatar
Drives: Mk7 1.4 tsi match edition
Nice how much was ur disks and pads set u back
Mikeyd1 is offline   Reply With Quote
Old 04-19-2017, 10:16 AM   #6
t-800
Member
Drives: RS3
Quote:
250 all in.
Old 04-19-2017, 11:19 AM   #7
Garynovis
Senior Member
Drives: 2015 GTi PP
Morning,
How did you wind back the rears (assumption that you have electronic handbrake), VCDS/OBDII?
What reason did you change them, were they worn out (if so, what mileage)?
Did you do a fluid change, if so was that straight forward?
Apologies for all questions, but brakes is one of the jobs I usually like to do myself, but those car jobs are getting less and less the more technology takes over
thanks
Garynovis is offline   Reply With Quote
Old 04-19-2017, 12:49 PM   #8
t-800
Member
Drives: RS3
Hi Gary
I changed them mainly because the Discs were rusty as hell, but wanting to do a proper job I did the pads too.
Yes you are correct the caliper motor needs backing off using VCDS 'lining change' mode, then the piston can be easily pushed back in.
Fluid not yet done though it's on the list along with DSG fluid.
Rear Caliper carrier bolts need renewing too as they are 90nm + 90 deg tightening angle.
Before the change.....
Old 04-19-2017, 01:37 PM   #9
Garynovis
Senior Member
Drives: 2015 GTi PP
Thanks,
And yes, agree, I would always do pads if changing discs
Old 04-19-2017, 02:36 PM   #10
ethanalice
Junior Member
Drives: R
New Bolts ?
"Rear Caliper carrier bolts need renewing too as they are 90nm + 90 deg tightening angle"
Any reason why these 2 bolts also need to change ? Also what you meant by spine bolts ?
ethanalice is offline   Reply With Quote
Old 04-19-2017, 03:03 PM   #11
t-800
Member
Drives: RS3
The bolts are M12 x 1.5 x 65 spline socket type.
Like these
They are angle tightened so cannot really be re-used
Old 04-20-2017, 09:52 AM   #12
jabba
Junior Member
Drives: VW Golf
Thumbs up
Great, many thanks for the info and the pictures
Old 04-20-2017, 12:39 PM   #13
pcr
Senior Member
Drives: golf gt 1.4 act
Is there any way to change the pads without using VCDS ? Thanks.
pcr is online now   Reply With Quote
Old 04-20-2017, 06:52 PM   #14
Mikeyd1
Senior Member
Mikeyd1's Avatar
Do I have to get rear calliper bolts on my 1.4 tsi?
Old 04-20-2017, 08:25 PM   #15
Mikeyd1
Senior Member
Mikeyd1's Avatar
Where did u purchase ur bolts mate
Old 04-20-2017, 10:18 PM   #16
t-800
Member
Drives: RS3
Trade parts specialists (TPS)
Old 04-21-2017, 11:56 AM   #17
Mikeyd1
Senior Member
Mikeyd1's Avatar
How much did u pay for the bolts? Thanks
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
