ashiun
Toronto, Ontario
Adjusting the FOL won't make it richer. Is this on the new firmware George has been giving out? Perhaps he is having it run leaner to match the other tuners. It looks good otherwise, but yeah would like to see what it does up near 6k and beyond.
I realized from the log my fuel bias reset to 0 again... even though it's set to 100 in the JB4 app. The AFR tap is secure so I guess this goes back to the warning that settings sometimes may rese on their own...
By the way, I read some posts about George mentioning higher trims (but less than 45-50) means more power. Since my trims are currently 30 or less, should I reduce my FOL to 40? It came shipped with 60 default by the way, even though George said it should ship with 40.
dub_guy
GTA
Thanks Diggs24.
I'll get these settings in and a log out soon. Maybe a day or say due to other responsibilities and I'll let you know how they worked.
Let's drop it just a touch in the mid range and carry a bit more up top:
1500 16
2000 17
2500 19
3000 21
3500 21
4000 22
4500 19
5000 18
5500 17
6000 16
6500 16
7000 15
Diggs24
de plains! de plains!
2015 GTI
Are you using the bluetooth? People wonder why I won't give up my crusty old laptop...it never has issues.
In regards to trims, trims will go up by default as you push more boost or use more E85. Artificially lowering it won't make the car go faster or the engine make more power.
demi9od
NC
I switched over to the app+USB. It's a lot easier to manipulate in vehicle.
dub_guy
GTA
Not even sure how that's possible. The dropdown doesn't have 25 fields from what I recall. Now I am intrigued. What is the software version?
Latest firmware and latest software.
Loaded the new firmware, left the laptop attached as I thought I might get a log and drove to work. Part way there had some weird stuff go on with the engine and when I checked at work the app said Map 25.
George said that could happen if either the serial or USB connection moves. I'll just say it is not something you want to happen.
dr_mk7_il
Israel
He did respond, and yes ROW GTIs run less boost and more timing.
Map6 is preset absolute and since your ECUpsi is different than ours it won't be +5psi for everyone (and it won't be +5 throughout...also IATs affect ECUpsi).
I don't particularly like map6 that it has default. It is weak down low and too strong up top.
There is good reason why we always say run a log no matter what. Everyone's car is different. Let's look at your last log:
https://datazap.me/u/drmk7il/151020...-3-4-11-18&trim=0&tmin=59.56&tmax=198.39&hg=1
Timing looks good early on for the amount of boost (which makes sense now) but then falters because it's too much boost.
Leave the low rpm as is.
5000 18
5500 16
6000 14
6500 13
7000 12
Thanks Diggs,
I made the change earlier today and juat had a short highway drive home, pulls quite smooth up top now but didn’t have A chance to log yet.
primaltugboat
Georgia
How does this log look?
https://datazap.me/u/primaltugboat/10-17-map-6?log=0&data=1-2-3-4-11&hg=1
I'm just JB4 map 6 with the following settings. This was from this afternoon with temp around 75 ish.
1500 - 15.0
2000 - 16.0
2500 - 17.0
3000 - 18.0
3500 - 19.0
4000 - 22.0
4500 - 23.0
5000 - 21.0
5500 - 19.0
6000 - 19.0
6500 - 18.0
7000 - 17.0
FOL - 50
Boost Safety - 27.0
Fuel Used - 93 Octane
Does it looks like I can get anymore out of it? or is it too aggressive in places?
jybyrd
Seattle, WA
1500 - 15.0
2000 - 16.0
2500 - 17.0
3000 - 18.0
3500 - 19.0
4000 - 22.0
4500 - 23.0
5000 - 21.0
5500 - 19.0
6000 - 19.0
6500 - 18.0
7000 - 17.0
FOL - 50
Boost Safety - 27.0
Turn it up early, turn it down later. Turn it up 1psi from 3000-4500,drop it 2psi from 4500+
Hunter's_MK7
I ended up on Map 25 today due to my laptop and usb cable...
I've had this happen to me twice. Both times I had just filled the tank up, left the laptop on while I turned the car off, drove a couple miles to work, then once I parked the car would idle funny, stall and jb4 would disconnect. It wouldn't let me reconnect right away, but after work I'd try and reconnect and it would be on map 25 or 46. I would set it back to 4, log, it looked fine, set back to 6, log, it looked fine so I never thought much of it.
I do run an e blend most of the time, and thought maybe the idle would be from the ECU adjusting to a higher e blend..but never threw a code or anything so I let it go.
Sent from my XT1585 using Tapatalk
