Catted DP and passing readiness
Radfox
Albuquerque, NM
Thanks for the response. Weird that your fuel level had to be a certain level. You can force readiness through VCDS, did you try that too? So I'm assuming just the "stock" file UNI provides worked?
How do you force readiness with a VCDS? What is the procedure?
Also what CEL code are you guys getting?
russiankid
PA
With a JB4, CTS catted DP and 42DD spacer facing the ABS module, there are no CEL's and passes all readiness monitors. The CTS catted DP has the O2 bung before the cat so the 42DD does a good job at keeping the CEL away.
bdelaney4000
Chester, NH
There's a video on youtube outlining the procedure just search for VCDS readiness. Most get the P0420 check engine light code for catalyst efficiency. Most aftermarket high flow cats aren't as efficient as the OEM cat causing the code. This can typically be defeated with a spacer to eliminate the CEL.
Rcode
LINY
Thanks. I was either going to try the vibrant or 42dd spacer but maybe I'll just buy both and see which works best.
mto386
New London, CT
2016 Golf R
There is no such thing as forcing readyness. You can force the ecu to run the test but that doesn't guarantee you'll pass. I have used the procedure above on my mk6 gti but when I had to smog my mk7 R that procedure doesnt work.
bdelaney4000
Chester, NH
"Forcing Readiness" is just the term commonly used to describe the procedure to "force" the ECU to run the tests without going having through a full drive cycle. Not every state run smog like CA. Looks like the OP is from Long Island.
Gawernator
Fremont, CA
FWIW I fixed my CEL last night. I got a $17 O2 spacer off Amazon and figured out the right config since its modular. You just have to play around with it until it works right
bdelaney4000
Chester, NH
Congrats! Yeah sometimes with those modular/adjustable ones you have to fiddle around with them to get them set just right. Glad it worked out for you though. :)
Gawernator
Fremont, CA
Thanks. I just unscrewed the lower section so reduce the overall size. It was throwing a lean code so it was too far out of the stream I guessed. Two days so far no code.
Rcode
LINY
Flashed to GIAC stage 2 today and the CEL that comes back every once in a while is gone. I left it on before the flash to see what would happen. Haven't had a chance to check readiness yet but I assume I'm still failing. Will try to get the 02 spacer in over the weekend and report back.
Rcode
LINY
Yes, correct no smog here. Just a description of the process instead of running the drive cycle.
