Old 03-13-2018, 07:19 AM   #1
Smoothcriminal
Drives: Golf mk7
Standard Mk7.5 rear lights on a mk7
Hi guys does anyone know our have any experience on the standard Mk7.5 rear lights onto a mk7?
Can they fit straight on to a UK car or are any mods necessary?
Just to confirm it's the bssic/standard rear lights on a mk7.5 and not the sweeping indicator ones.
Thanks in advance
Smoothcriminal is offline   Reply With Quote
Old 03-13-2018, 03:17 PM   #2
JBale
JBale's Avatar
Drives: 2015 GTI
Thanks in advance
You would need to play with the coding as well as use some kind of adapter since the connectors are not the same. Do you have mk7 LED tails currently or the incandescent one?
JBale is offline   Reply With Quote
Old 03-13-2018, 04:10 PM   #3
Smoothcriminal
Drives: Golf mk7
I have the standard mk7 rear lights, LL JJ on a 2.0 tdi but I was thinking of refreshing the back end
Old 03-13-2018, 04:29 PM   #4
JBale
JBale's Avatar
Drives: 2015 GTI
Since you have the standard tails I believe you only have 3 wires to your outer lights currently (Brake/ Runner, Turn signal, and ground). For the facelift tails to work you will need 4 wires, as the runner and brake are separate on the new tails. You'd need to pull the signal for the running light from the hatch mounted tail lights (or the BCM if you're felling adventurous lol). Feel free to send me a PM if you want a harness that can make this work for you.
Old 03-15-2018, 08:18 PM   #5
Smoothcriminal
Drives: Golf mk7
I see your from Canada so that may be a problem
Anybody else can share thoughts?
Old 03-15-2018, 09:54 PM   #6
ZERO815
ZERO815's Avatar
Drives: '17 GTI
Jeremy is right. With your car you need an additional running light wire to the outer tails but you can grab it at the inner lights. Furthermore you need different connectors and coding.
'17 GTI SE DSG|BILSTEIN B16|obdeleven|Dynamic LED tails
ZERO815 is offline   Reply With Quote
Old 03-17-2018, 02:05 AM   #7
Smoothcriminal
Drives: Golf mk7
What is the approx cost of the wiring, connectors and coding.
May not be cost effective to do this I'm starting to think..
Any other upgrades you can recommend?
Old 03-17-2018, 05:14 AM   #8
Jose_Gti
Jose_Gti's Avatar
Drives: Golf GTI MK7
Why donít you try the 2015-17 MK7 VW GTI CHERRY RED OEM LED TAIL LIGHTS?
Those should be plug and play.
https://rover.ebay.com/rover/0/0/0?m...2F192310989286
MK7 MT GTI APR stage II high output + APR Down Pipe. APR Intake. Denso IKH24 Iridium plugs. 034 Dogbone. APR short shifter full system. ECS Clutch Bleeder Block. Billy Boat Resonator. TTRS Clutch kit. UBQ unibrace and Neuspeed sway bar.
APR Intercooler + Apr boost hoses, apr turbo inlet pipe.
Jose_Gti is offline   Reply With Quote
