LED Number plate lights help
djmarksmith
Newcastle
hey guys i have done some searching and eventually bought some lights for the number plate to change to LED.
Having problems though as it doesn't matter which ones i use im getting errors on the MFD
Anyone know if this is common or how to code them in or even where i can buy ones that dont give me the errors
nype
Vancouver, B.C.
Buy an Obdeleven Pro and code many more things than just disabling LED plate light errors.
Also, try searching. Google is your friend.
deAutoLED.com
GolfMK6 Official Vendor
ny
100% error free model:
http://deautokey.com/product/mkvii-gti-license-plate-leds-error-free-plug-play
This is the only model we have seen that are 100% error free in the 2017+ with auto-headlights also.
We have been receiving a lot of emails where people are buying "error free" LEDs for the new MK7 GTI and they are triggering errors. With our product there is no coding required. Clean bright white with no yellow/blue tinting:
djmarksmith
Newcastle
Im assuming that the obdeleven is just a OBD dongle and i can use VCDS to do the same thing ?
I did a google today and i think i found the correct adaption ??
Select STG 09 (wiring)
STG access permissions -> Function 16
Enter Unlock Code 31347
STG adjustment -> function 10
(1) Select Leuchte25KZL HA59-load type 25
Customize LED general - value at 43
(6) Leuchte25KZL HA59 dimming AB-25 Select
Adjust value to 127
nype
Vancouver, B.C.
Well Obdeleven is sort of an alternative to VCDS. It’s Bluetooth based and requires an Android device. Much cheaper than VCDS and more user friendly.
But ya, if you have VCDS already, that looks like the correct coding.
djmarksmith
Newcastle
That’s brilliant and thanks for the info. I’m a mechanic and have a full version of VCDS but I’ used to doing steering calibrations, handbrakes resets etc so playing with adaptions will Be an experience
