FORUM OPTIONS
Go Back   GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum > Technical Topics > DIY Guides and Discussions
Reply
Thread Tools Display Modes
Old 10-02-2017, 10:53 AM   #1
SM075180
Member
SM075180's Avatar
Drives: 2017 Volkswagen Golf GTI SE 6MT
Seat Belt Anchor Adjustment?
Curious if someone could let me know if the seatbelt receptacle on an MK7 GTI is adjustable in its positioning. Is there a pivot point between the console and seat? Or is it height adjustable?
As of now I find it floats the belt away from my hip in an awkward way as Iím a smaller guy.
Thanks in advance!
__________________
2017 VW GTI SE 6MT PP
Deep Black Pearl/Titan Black/GTI SE Lighting Package
Rayno Platinum Air7090 W/S
Rayno S9 50% F/R S9 35% H
Burger MS Clutch Stop (all washers)
SM075180 is offline   Reply With Quote
Old 10-02-2017, 05:17 PM   #2
golfdave
Senior Member
Drives: Defensively, avoiding all the other idiots!!
Not the only one.
What VW has done is increase the length of metal "stalk" that the lock (black bit with red button) has between it & the fixing point which is the bottom part of the seat frame rail below.
This puts the lock part further up & forward, so that for bigger people they don't have to reach around as far....
But for us slim people (used to be normal) it causes the lap part of the belt to be held away from the body & I find it floats away easy..
I a CG-Lock? device (original) on my previous car & yes it will fit this, but again its at an awkward angle due to the position of the "lock"...so I got their newer shoft? device:-
http://shoft.co.uk/
Much better !!
__________________
VW Golf Mk7 Estate GT, 1.4TSI 140PS, 6 speed Manual, Tungsten Silver Metallic | Titan Black | Loads of factory options & OEM ++ mods
My Build:- Click Here
All of my "How-to" Guides:- Click Here
golfdave is online now   Reply With Quote
Old 10-03-2017, 05:03 AM   #3
SM075180
Member
SM075180's Avatar
Quote:
Originally Posted by golfdave View Post
Not the only one.
http://shoft.co.uk/
Much better !!
Thanks for chiming in but itís not and issue of seatbelt slipping or posture for me. I just think itís an awkward aesthetic thing to have that void of space there.
__________________
Old 10-12-2017, 09:49 AM   #4
SM075180
Member
SM075180's Avatar
Just came across a thread from 2015 which left a vague hope thereís a solution- but didnít solve.
__________________
Old 10-12-2017, 10:18 AM   #5
Gti jake
Senior Member
Drives: GTI 6MT
You wanna modify a safety device for aesthetics?
Wasn't sure if that sank in yet lol. Stop looking down at your seatbelt, you'll hurt your neck...
__________________
'16 GTI 6MT PM for NC/SC help with Installs & Fabrication
Gti jake is offline   Reply With Quote
Old 10-13-2017, 03:49 PM   #6
SM075180
Member
SM075180's Avatar
Not for aesthetics mate. It holds the belt ~2Ē inches away from my right hip. Seatbelts canít do their job if they donít you know... restrain you.
Where did you get the idea I wanted to try and make a seatbelt pretty?
__________________
Old 10-13-2017, 04:57 PM   #7
ecsta
Member
Drives: 2017 R
You literally said "I just think itís an awkward aesthetic thing to have that void of space there" lol
Personally i wouldn't mess with the safety device. Maybe put one of those little airplane pillows behind your lumbar that'll push you forward a bit, or move the seat up.
ecsta is offline   Reply With Quote
Old 10-13-2017, 11:16 PM   #8
SM075180
Member
SM075180's Avatar
Hah touchť. I had only looked at my original post when I read yours. Iíve been slammed into by a drunk driver and nearly died. I assure you Iím not going to mess with it unless itís designed to adjust. Lol
__________________
Old 10-14-2017, 08:13 AM   #9
golfdave
Senior Member
Calm down everyone...
Listen I explained in my post no3 why & what has happened to the "stalk"...
The onlt thing you can do is remove the item & replace it with one that has a shorter stalk...but you have to find one that has the stalk with the correct mounting bit
Ours is item 11 & there are two versions which I think are because of "standard" & sport seat...or electric..
https://volkswagen.7zap.com/en/rdw/g.../8/857-857065/
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
